Is Simplifying Snell's Law to n1θ1=n2θ2 Valid for Small Angles?
  • Thread starter Thread starter rjs523
    Approximation Law
Simplifying Snell's Law to n1θ1=n2θ2 is a valid approximation for angles below 10 degrees, as the sine function can be approximated by the angle in radians. This simplification provides sufficient accuracy for practical applications within that range. It is important to measure angles in radians to ensure the approximation holds true. The discussion also notes that errors in the sine terms tend to cancel each other out, further supporting the validity of the approximation. Overall, this method can be effectively used for small angle scenarios in optics.
rjs523
Can you take the sin terms out of Snell's Law when dealing with angles below 10 degrees? so Snell's Law would be become n1\theta1=n2\theta2
Thanks
Science news on Phys.org
That would be a fairly good approximation as long as the angles stay within that range. (Do a few examples to check that it gives you sufficient accuracy for your needs.) Be sure to measure the angles in radians!
welcome to pf!
hi rjs523! welcome to pf! :smile:
(have a theta: θ and a degree: ° and try using the X2 icon just above the Reply box :wink:)
the error in one sine would be (θ3/6)/θ, or θ2/6
since both errors would be in the same direction, they will to some extent cancel out,
to … ? :smile:
Thanks a lot for the help and the warm welcome :smile:
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
