Is the acceleration of mass A equal to mass B in Born rigid motion?
  • Thread starter Thread starter Ironhead
    Acceleration
Ironhead
Suppose I am standing in an inertial reference frame and watching two point masses A and B accelerate according to the rules of the Born rigidity. The distance between the masses is L in an inertial frame in which A and B are simultaneously at rest. Mass A is 'in front' of mass B. Mass B has a fixed constant acceleration aB. What is the expression for the acceleration aA of mass A?
If they move in a Born rigid way while one of them is doing constant proper acceleration, the other one is too. The rear has a higher proper acceleration than the front. (Otherwise the distance between them in the original rest frame wouldn't decrease). Check out the Wikipedia page for Rindler coordinates. The world lines of A and B are two different hyperbolic arcs in the first picture. See also this thread, in particular DrGreg's posts.
Assuming the accelerations are proper accelerations (not coordinate acceleration, otherwise it wouldn't be Born rigid motion)
L = \frac{c^2}{a_A} - \frac{c^2}{a_B}​
I prefer to state that as aA=aB/(1+aBL/c2).
Taking Newtons formula for gravity F=GMm/r2 for mA and mB and assuming mass A is above mass B in a planet M gravity field, or
L=rA-rB, you can get the same type of expression for a planet gravity field: aA=aB/(1+L/rB)2
The Equivalence Principle says these two should be equal? Am I wrong?
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
