Is the Configuration of Magnetic Fields Only a Convention?
The discussion revolves around the nature of magnetic fields and whether their configuration is merely a convention. Participants explore the historical development of electric and magnetic fields, referencing Faraday and Ampere, and consider the implications of defining magnetic fields based on different perspectives, such as the force on test currents versus source currents.
  • Some participants suggest that the concept of magnetic fields could have been developed differently, such as by considering the force on one electric current in the presence of another, similar to Ampere's findings.
  • Others argue that changing the convention of magnetic fields would require altering Maxwell's equations, indicating a dependence on the established framework.
  • It is noted that the direction of magnetic fields is a convention, which can be altered by changing the right-hand rule or the order of cross products.
  • Some participants express uncertainty about the implications of defining field lines based on the force between currents, suggesting that this could lead to fields that do not reflect the actual behavior of currents.
  • There is discussion about the magnetic vector potential and its relationship to magnetic fields, with some proposing that auxiliary fields might be introduced for computational ease.
  • Participants highlight that the direction of the magnetic field could be well-defined, but there is contention regarding whether this definition aligns with the forces experienced by test currents.
Participants do not reach a consensus on whether the configuration of magnetic fields is merely a convention. Multiple competing views are presented regarding the implications of defining magnetic fields based on different criteria.
Some discussions involve assumptions about the nature of magnetic fields and their dependence on historical conventions, which may not be universally accepted. The complexity of relating field lines to the forces on currents introduces additional uncertainty.
  • #31
Ok, yes. I think that was the case in the 19th century, where no charged particles and the em. forces on them were observed yet, but only after Oersted discovered the close relation between currents and magnetism, which was only possible since physicists could have steady currents through the discovery of Volta and Galvani before. The first charged particles at disposal for experiment were of course electrons (discovered by Thomson in 1897) and the related "electron theory" by Lorentz.
Before all that it wasn't even known that electricity and magnetism are related, and the physicists considered only permanent magnets discribing them by "poles", being well aware phenomenologically that single magnetic poles are not observed but only in terms of "dipoles".
  • #32
Vanadium 50 said:
My beautiful Latex was destroyed. (Greg, is there a Purple Heart badge for this?) I tried to write:
[tex] \nabla (A^2/2) - ({\bf A} \cdot \nabla){\bf A}[/tex]
What's a vector and what is not is important.
All you have to do is invert this. :wink:
Would you be able to show me how you derived this?
  • #33
Could you remind me, what this term (there's no equation) was supposed to be used for? I'm a bit lost about what the actual mathematical or physical question is o_O
  • #34
In post #6 you described the field I was trying to describe in the OP as: "it would be some field like B×A so that it was perpendicular to both". So the other side of the equation would be B×A (if I understand correctly). Thank you!
  • #35
That wasn't me. I've no clue, where the gauge-dependent expression ##\vec{B} \times \vec{A}## might come from. AFAIK it has no immediate physical meaning to begin with.
  • #36
Sorry, you're right, it was Vanadium50. The reasons motivating it are in the OP.
  • #37
If you want to make a field point in that direction, you need something like B x A to point in that direction. Replacing B with A gives the expression in Post 22.
I don't know why this thread was restarted after more than a month, but I see nothing that suggests the original idea is superior in any way whatsoever to the conventional formulation. It adds a lot of mathematical complexity for no good reason.
  • #38
cg0303 said:
But if the field lines were based on the force between currents, the field lines would diverge from currents rather than curl around them.
Even if you could get such a scheme to work, it wouldn't be general enough to explain the way a magnet interacts with a current-carrying wire, or the way magnets interact with each other.
Faraday was well aware of the way magnets interact with each other before he ever started to develop an explanation for the way they interact with current-carrying wires as it had been known for about two centuries before Faraday did his work.
  • #39
One way to reverse magnetic field direction is to change convention of charge sign. Say electron has positive charge and proton has negative charge, current in circuit reverse, so the generated magnetic field reverse also. Electric field also.
  • #40
An argument can be made that while there is additional mathematical complexity, the fundamental idea behind it is simpler. This is because it makes magnetism more symmetrical with electricity because the magnetic field would diverge in the same way the electric field would (see post #4). The sources of the fields would also be more similar, with the source of electric fields being charges and the source of magnetic fields being moving charges.
  • #41
I like this idea. However here in physics forums most mentors and moderators are not friendly to new things, they want to discuss only mainstream or should i say well established physics. Your ideas might be revolutionary but are not discussed in any well known book, or a peer reviewed paper. However i like it as i said. I still consider physics forums one of the best site in the internet to discuss about mainstream science (mainly physics and math), but they have the disadvantage i said above.
Nothing new here, this is well established in classical electromagnetism since Maxwell's era 1850s-1860s. I would also add that according to classical electromagnetism, sources of electric field are time varying currents(accelerating charges).
  • #42
Well, obviously it hasn't been answered, whatever was asked. Which direction want you to point the field to and for what purpose?
  • #43
It would point in the direction of the force on the test moving charge. Although it would also be a matter of convention in the same way that electric field lines point away from positive charges by convention.
  • #44
The Lorentz force is part of the usual Maxwell electrodynamics (in SI units),
$$\vec{F}=q (\vec{E}+\vec{v} \times \vec{B}).$$
Of course, there are also some conventions in the definitions, but you don't have too much freedom. That's because Maxwell's theory is a relativistic field theory of a massless spin-1 field, which is necessarily a gauge field (because you don't have continuous polarization-like degrees of freedom), and this fixes to a great extent the dynamics of the system of charges and the field.
Of course, there are certain conventions, which in principle you could change, but at the end the physics stays the same of course. E.g., you can use the east- or west-coast convention of the Minkowski bilinear form. These two possibilities are even used in parallel in the literature for decades now. It's just your personal choice in the beginning of your physics education, depending on the scientific community within you do research.
Other issues are more consistently settled by tradition. E.g., in 3D vector calculus everybody uses the right-hand rule to define the various orientations occurring in the fundamental theorems: The orientation of the boundary of a surface is related to the arbitrary orientation of the surface-normal vectors (important in Stokes's theorem). The boundary surface's normal vectors of a volume are always defined by convention to point out of the volume (the only exception I know of is the very valuable classic textbook on relativity by von Laue) etc. Of course, you could redefine all these conventions, but that's not useful for anything. At the end the physics is the same.
  • #45
Convention of reversing magnetic field should be accompanied by reversing electric field so that Poynting vector which is flow of energy has to be unchanged. Here I do not refer changing rules of mathematics, e.g. vector product A X B.
  • #46
But what should all this redefinition be good for? I'm glad that at least the signs of the field components are uniquely defined in the literature. It's already a nuissance to still have at least three different systems of units (non-rationalized Gauss, rationalized Gauss (aka Heaviside-Lorentz), SI) and all the different sign conventions in relativity (##\eta_{\mu \nu} = \pm \mathrm{diag}(1,-1,-1,-1)##, ##\epsilon^{\mu \nu \rho \sigma}##,...).
  • #47
Well, if magnetic fields are defined by the force they apply to moving charges, then it follows that magnetic field would do work. It could be that in the end the physics still remains the same, but I'm not sure.
I'm aware, as pointed out in #41, that this make take the thread outside the forum guidelines. Just flagging it as a possible concern.
  • Skeptical
  • #48
From the Lorentz force it immediately follows that magnetic fields don't do work. The power is
$$P=\dot{\vec{v}} \cdot \vec{F}=q \vec{v} \cdot \vec{E}.$$
  • #49
An excellent question. This dead horse keeps getting flogged, and I don't understand why.
  • #50
I think the OP would like to drop the concept of the magnetic field, instead using some field they (confusingly) keep calling a magnetic field, which points in the direction ##\vec v\times\vec B## ("in the direction of the force on the test moving charge", as in #43). OP seems to feel that this would be more intuitive.
It seems to me that this implies that the force field isn't well defined, since two charges may pass through the same point with different velocities. Unless I, too, fail to understand what the OP wants.
  • #51
Then show us your calculations that prove that.
  • #52
My question is whether the magnetic field could have been defined differently. A differently defined magnetic field would still be called a magnetic field.
  • #53
Maybe. It's still confusing to refer to your hypothetical definition by the same term used for a mainstream concept.
I notice you didn't comment on the rest of my post. Am I correct in understanding that you want to define a field that points in the direction ##\vec v\times\vec B##?
By the way, if you are still able to edit your post would you mind removing the "of" you seem to have inserted after "instead" in your quote of my post?
  • #54
I made a mistake. I mistakenly thought that if the magnetic field and the force on the charge were not perpendicular, the magnetic field would do work. In reality, only if the charge's velocity and the force on the charge were not perpendicular, the magnetic field would do work.
An embarrassing mistake on my part. You were right in pushing me to show my calculations, that way I caught it.
  • #55
I don't know what else to call it. I guess I could just say the "hypothetic magnetic field".
Yes, I want to define a field that points in the direction of v × B.
  • #56
Done
  • #57
But how would it work when there is no moving charge and hence no ##\vec{v}##? How would you describe interaction of two magnets?
  • #58
In addition to @weirdoguy's point, then, how do you define this field when two or three particles pass through the same point with different velocities? Your field has different strengths and directions from the same source at the same point.
cg0303 said:
Done
Thank you.
  • #59
Ok, but this doesn't make sense from a conceptual point of view. The important paradigm change from Newtonian mechanics, where interactions are treated as action-at-a-distance forces, is the concept of locality, i.e., one introduces fields as "mediators" of interactions. In Newtonian mechanics you can also take this standpoint of the field concept, but there it doesn't really change the qualitative picture, because all that's done is to introduce a static field. In practice that are electrostatic fields and the gravitational field. However, the idea is already clear in these cases: You first calculate a field, independent of the test particle moving "in this field", which mediates the interaction/forces.
E.g., in Newtonian theory of gravity you start with the field equation
$$-\Delta \Phi(\vec{x})=-4 \pi G \rho(\vec{x}),$$
where ##\rho## is the mass distribution of the "source of the gravitational field". The solution of course is
$$\Phi(\vec{x})=-G \int_{\mathbb{R}^3} \mathrm{d}^3x \frac{\rho(\vec{x}')}{|\vec{x}-\vec{x}'|}.$$
Then the gravitational force on a test mass is given by the potential
$$U(\vec{x})=m \Phi(\vec{x}).$$
the important point here is that the field ##\Phi## is independent of the test mass, upon which the force acts.
The same you have with electrostatic fields as well as magnetostatic fields and test charges in Newtonian physics. The important point also here is that the field is independent of the properties of the test charge. So no quantities related to it appear in the fields, neither the charge nor the charge's velocity.
The field concept and the locality concept becomes, however, crucial in the context of relativistic physics, where the fields necessarily becomes a dynamical entity of its own. It's not just a mathematical trick to "mediate forces" but is a fundamental dynamical "thing" for itself, as "point particles" or "fluids" are fundamental dynamical entities for themselves within classical physics. The strict locality in space and (!) time of the successful dynamical models within the theory of relativity are key for the consistency with relativistic spacetime models and particularly causality.
To make a long speach short: It doesn't make sense to intermingle properties of the (test) particles/fluids with the field but keep everything within a strictly local description.
  • #60
Magnets have the properties they do because of the motion of the charges inside them. It would probably take a lot of work to figure out how to apply the hypothetical magnetic field concept to two magnets, but it seems possible in principle.
  • · Replies 20 ·
  • · Replies 42 ·
13K
  • · Replies 24 ·
