The propagation velocity of signals in cables decreases significantly at low audio frequencies, specifically slowing down to 5EE6 m/sec at 20Hz, as noted in a paper from Belden cable company. This reduction in velocity is attributed to the increased characteristic impedance of cables at low frequencies, where the skin depth becomes comparable to the conductor thickness. Calculations indicate that at 20Hz, the phase shift through a 1-meter cable is approximately 1.44 degrees, which is minimal for typical interconnect lengths. The discussion emphasizes that while the velocity reduction is notable, the practical implications on audio performance may be negligible.
- Understanding of electromagnetic theory, specifically the relationship between frequency, impedance, and propagation velocity.
- Familiarity with cable characteristics, including skin depth and capacitance.
- Knowledge of RF (Radio Frequency) principles and their application in audio systems.
- Basic mathematical skills for calculating phase shifts and propagation delays in transmission lines.
- Research "characteristic impedance in low-frequency cables" to understand its impact on audio performance.
- Explore "skin depth effects in conductors" to gain insights into how frequency affects signal transmission.
- Study "phase dispersion in transmission lines" to evaluate its significance in audio applications.
- Investigate "Belden cable specifications" for detailed information on cable performance across different frequencies.
Audio engineers, cable manufacturers, and anyone involved in the design and optimization of audio transmission systems will benefit from this discussion.
