Is the Right Hand Rule for Magnetism Really Necessary?
  • Thread starter Thread starter pray_for_mojo
    hand
The discussion centers on the necessity of the Right Hand Rule in magnetism, particularly its application to positive and negative particles. While the Right Hand Rule is conventionally used, some suggest employing the Left Hand Rule for negative particles to simplify learning. However, it is argued that switching directions for negative particles still requires using the Right Hand Rule, maintaining consistency in application. The conversation highlights that the choice of convention, whether right or left, is arbitrary and does not affect the underlying physics. Ultimately, the consistency of using one rule is deemed more beneficial for students learning physics.
pray_for_mojo
All of the books and experience I can find offer only a Right Hand Rule for magnetism (current in a wire, particles). Since this is good for only positive particles, students must remember to switch the direction of the force when using the rule. Why not just use the left hand for negative and the right for positive? Am I missing something? It seems the easier and more logical way to go.
Well flemming stole the left hand rule for showing the force on a current carrying conductor in a magnetic field. I presume it would just be confusing if there was an alternative for each one.
I would think that with a negative particle, the vector is pointing in the opposite direction, so you really still need to apply the right hand rule.
If the field and the velocity are the same the only difference is in the direction that your thumb is pointing (force). For students new to physics, is it more confusing to suggest they remember to switch the direction of the force in their minds as opposed to using their left hand? ...Fleming aside...
The right hand rule is just a convention. As TheDude said, you always apply the right hand rule, even for negative particles. We could just as easily have decided to use a left-hand rule, and everything would work just the same -- theories would still make the same predictions. All that matters is that you are consistent with the convention.
The presence of such a choice is actually a rather deep characteristc of our physical universe. It turns out that the concepts of a vector and a dual vector are different in spaces of all dimension except three; the cross-product and its freedom for a convention can only exist in three dimensions.
- Warren
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
