Is the Vector Product Really a Vector?
  • Thread starter Thread starter golshah
    Physics
The discussion centers on proving that the vector (cross) product is indeed a vector in the context of physics and mathematics. It highlights that the cross product's definition leads to a resultant vector that is orthogonal to the two input vectors, which aligns with the characteristics of a vector. Participants question the criteria for defining a vector, such as transformation rules and properties that must be satisfied. The conversation emphasizes the importance of understanding these definitions and properties to validate the nature of the cross product. Ultimately, the discussion seeks clarity on the foundational aspects that classify the cross product as a vector.
golshah
How can I prove that the vector (cross or external) product is really and physically a vector. I face with this problem in math physics course.
thanks for your hint.
I think the fact that the crossproduct is a vector follows immediately from the definition of the cross product.
you find torque with the cross product you need two vectors in order to find it and the resulting torque is normal to the other 2
What are you using as a definition of a vector? For example, does a vector obey a certain transformation rule? Does the cross product satisfy the required properties.
