Is the Work Done by a Variable Force Non-Conservative?
59 replies · 6K views · last reply
MatinSAR
How can I find work done by variable force using F.dr When the equation of path is x=(2a) sinθ and y=(a) cosθ and F=(x^2) y i + x(y^2) j? If you can guide me how to write the integral relation so that I can calculate it, I would be grateful.
W=Int(F.dr)
Can anyone tell me if my answer is wrong ?!
Handwritten derivation of the work integral W = ∫F·dr for F = x²y i + xy² j along a parametric path r = 2a sinθ i + a cosθ j, ending with the result nxya(-2x+y).
Just to clear things up:
$$r(t) = x ~\mathbf{\hat{i} } + y ~\mathbf{\hat{j} } = 2 a \sin t ~ \mathbf{ \hat{i}} + a \cos t ~ \mathbf{\hat{j}}$$
$$ F(t) = x^2 y ~\mathbf{ \hat{i} } + x y^2 ~\mathbf{ \hat{j} }= ( 2 a \sin t )^2 a \cos t ~\mathbf{ \hat{i} } + 2 a \sin t (a \cos t )^2 ~\mathbf{ \hat{j} } $$
Correct?
Assuming that you are asked to find the work done by the force from ##t=0## to some arbitrary time ##t##, you can write $$W=\int_0^t \mathbf{F}(t')\cdot d\mathbf{r}=\int_0^t \mathbf{F}(t')\cdot \frac{d[\mathbf{r}(t')]}{dt'}dt'$$which you can easily integrate because you are given both the force and the position vector as functions of time.
Chestermiller said:
What is F equal to in terms of "a" and ##\theta##?
Handwritten vector field F = x^2 y i + x y^2 j, followed by its parametrised form F = (4a^2 sin^2 θ)(a cos θ) i + (2a sin t)(a^2 cos^2 θ) j.
$$r(t) = x \, \rm{\hat i} + y \, \rm{\hat j} = 2 a \sin t \, \rm{ \hat i} + a \cos t \, \rm{\hat j}$$
$$ F(t) = x^2 y \, \rm{\hat i }+ x y^2 \, \rm{\hat j} = ( 2 a \sin t )^2 a \cos t \, \rm{\hat i} + 2 a \sin t (a \cos t )^2 \, \rm{\hat j } $$
Correct?
Yes.
Thanks a lot. I have seen a formula like this before.
I think my mistake is that I did not consider the unit vector tangent to the direction of movement.
Can you please tell me what is that t' ?!
And we have position vector as functions of θ ...
Its just a "dummy variable" so the variable of integration is not the integration limits variable. Alternatively you could leave the force and position in terms of ##t## and switch the limits to ##0 ## and ##t'## or ##0## and ##t_f## is quite common
That ##t'## is a dummy variable of integration that distinguishes it from "any time ##t##" that appears as an upper limit. It's a rigorous way to show what one is integrating with respect to. For example, $$\int_0^t 2t'dt'=\left . t'^2 \right |_0^t=t^2.$$
MatinSAR said:
Homework Statement:: How can I find work done by variable force using F.dr When the equation of path is x=(2a) sinθ and y=(a) cosθ and F=(x^2) y i + x(y^2) j? If you can guide me how to write the integral relation so that I can calculate it, I would be grateful.
Relevant Equations:: W=Int(F.dr)
Please don't edit your original post to change the statement of the problem. In the original version, the force and postion vectors were explicit functions of time. Now they are not. What is going on?
I am so sorry I didn't know that editing the original post is not allowed ...
I was trying to write theta but I couldn't. I have sent a picture and in that picture x and y are functions of θ.
It would be better if you could just learn to use the math formatting available to you on the site: Latex
Can I replace θ with t' ?!
Yeah, you replace it with whatever variable you want.
What is ##\theta## here? It can't be the argument parameter of the polar representation of (x,y) since we would deduce ##\tan^2(\theta)=\frac 12##. So I assume it is an arbitrary parameter unrelated to polar coordinates. But then, where do the integration bounds come from?
I see no diagram.
I guess you mean replace t' with ##\theta##.
Don't know what post #1 said originally (helps if the first responder always uses 'reply'), but it now gives force as a function of position.
@MatinSAR , to use kuruman's approach you will need to find force as a function of theta.
haruspex said:
What is θ here?
Thank you ...
x and y are the equations of a part of an ellipse. We are going from a to c.
Diagram of a curved dashed path from A(0,a) on the y-axis to C(2a,0) on the x-axis, with corner B(2a,a) marked by dashed guide lines, next to the force F = x^2 y i + x y^2 j and parametric equations y = a cos θ, x = 2a sin θ.
I have tried to use that integral but I failed and My teacher said that my answer is wrong again ...
He suggusted using polar coordinates to answer the question.
Work integral written as W = ∫ F·dr = ∫ F dr cos θ, with vectors F and dr shown with arrows and a dot product between them.
We can convert F to polar coordinates like this : https://www.physicsforums.com/threads/work-done-by-variable-force.1047266/post-6821666
Then we can find it's magnitude ...
Magnitude of dr is rdθ ...
But I don't know what is cosθ here... Can you please guide me about this ?!
Draw a line from the origin to any point on the ellipse. Try to figure out what angle ( w.r.t the axes) ##\theta## must be such that the ##x## coordinate is given by ##2 a \sin \theta##.
I have tried to find a similar example in many Classical Dynamics and Physics books but I didn't find anything similar ... I have searched the web also ... Do you know a bookthat has a question like this ?!
Diagram of a curved path in the first quadrant from A(0,a) on the y-axis to C(2a,0) on the x-axis, with corner B(2a,a) and origin O. A red position vector r points from the origin to a point on the curve; two angles are marked theta, one above r and one below it, with dashed guides to the axes.
## \vec r ## is the position vector. Which ##\theta## ( above ## \vec r ## or below it ) reconciles with ##x = 2 a \sin \theta## ?
MatinSAR said:
Thank you but what do you mean by this ?! I didn't understand.
This one should be Theta ...
Using that angle if you plug in ##\theta = 0 ## what does ##x## equal?
Theta=0 means x=0 and y=a
Does that seem correct to you?
According to the diagram no it's wrong ... so the other one is theta and I have chose the wrong one ...
I recommend that you try to reason your way through this one instead of trying to find one like it. You'll end up getting higher test scores.
Forget ##\theta## as a variable. Try this. You have $$x=2a\sin\theta~;~~2y=2a\cos\theta.$$It follows that $$x^2+4y^2=4a^2 \implies xdx+4ydy=0 \implies dx=-\frac{4y}{x}dy$$ Now $$\mathbf{F}\cdot d\mathbf{r}=(x^2y~\mathbf{\hat x}+xy^2~\mathbf{\hat y})\cdot(dx~\mathbf{\hat x}+dy~\mathbf{\hat y})
=x^2ydx+xy^2dy.$$ Substitute the expression for ##dx## and integrate over ##y##.
If you are going from A to C, the limits of integration are from ##\theta=0## to ##\theta = \frac{\pi}{2}##. From the equations for F and dr that I gave in post #16, what is the equation for F dotted with dr?
Thank you but I was looking for a similar question that has an answer to understand how to solve these kind of questions.
Thanks a lot !
I have done this before but I didn't know anything about the substitution. I will try thank you ...
Thank you.
I will try to answer the problem using this method and compare with the method that Mr.kuruman said ...
