Is there a simple energy simulation for non-specialized use?
  • Thread starter Thread starter abdullah khaled
    Energy Simulation
A user seeks a simple energy simulation model for a light bulb project, specifically to avoid thermal issues, without a background in mechanical and energy fields. Clarification reveals the user is looking for a thermal model that operates under varying input voltages and output powers. Suggestions include conducting a Google search for thermal models of light bulbs to find relevant resources. Additionally, using LED bulbs is recommended due to their lower heat emission. The discussion emphasizes the importance of finding accessible simulation tools for non-specialists.
abdullah khaled
hi
i want to make a simple model for a light bulb for a project i am not "Mechanical and energy" specialized i just need it to avoid any thermal issues.
is there a simple energy simulation for non-specialized use?
thank you.
abdullah khaled said:
hi
i want to make a simple module for a light bulb for a project i am not "Mechanical and energy" specialized i just need it to avoid any thermal issues.
thank you.
Welcome to the PF.
When you say "module", do you mean "model"? You want to make a thermal model of a light bulb, running at different input voltages and output powers?
Welcome to the PF.
i'm sorry about that :) yes i meant model running at different input voltages and output powers
Consider using LED bulb as they emit far less heat.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
