Is there a term for the vertical elongation of a planet?
The discussion revolves around the concept of "vertical elongation" of a planet, specifically referring to its angular distance above the horizon at sunset. A mathematical formula is provided to illustrate this concept, indicating that the vertical elongation can be calculated using the angle between the ecliptic and the horizon. The term "prolate spheroid" is introduced to describe a sphere elongated along its semi-minor axis, contrasting it with an oblate spheroid. However, a clarification is made that the original use of "elongation" pertains to the planet's position in relation to the sun, rather than its physical characteristics. The conversation highlights the importance of context in defining astronomical terms.
dotancohen
Is there a term for the vertical elongation of a planet? This would be the angular distance above the horizon that a planet appears at the instant the sun sets, or in mathematical terms it would be:
x=elongation
theta=angle between the ecliptic and the horizon
"vertical elongation" = x * sin(theta)
Astronomy news on Phys.org
Note that the formula assumes that the planet actually lies on the ecliptic, which of course is rarely the case. But I use the formula to illustrate.
Yes indeed, such a word exists. If a sphere is elongated along its semi-minor axis (vertically, in this case), then it is known as a prolate spheroid. This is opposed to a oblate spheroid, in which the sphere is elongated at its equator.
So to answer your question: "prolateness", I suppose would work. And the dictionary confirms that it is a word.
Thanks, SpiffyKavu, but I think that we are using different definitions of "elongation". I am using "elongation" in the sense of angular distance from the sun:
http://en.wikipedia.org/wiki/Elongation_(astronomy)
I do not refer to a physical feature of the planet's material, but rather the planet's position in the sky relative to the sun. I apologize, I thought that the definition would be clear here from the context. In fact, I did not even think of the other definition.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
