Is There a Way to Prove Normalization of the BCS Equation?
  • Thread starter Thread starter michaeltorrent
    Superconductor
michaeltorrent
hi
i have superconductor question, need someone familiar with this field.
does anyone know how to prove normalization of bcs equation?
<psi|psi>=1
given uk^2 + vk^2 =1
i went through the Heisenberg algebra but still can't solve it.
any guide?
The BCS wavefunction can be written as a product of factors like u_k | 0 ,k\rangle + v_k | 1,k \rangle where the states refer to an unoccupied or occupied Cooper pair (k spin up, -k spin down). The normalization condition boils down the normalization of these factor states. Using the fact the | 0,k \rangle and |1,k \rangle are orthogonal, can you prove that you must have u_k^2 + v_k^2 = 1 for normalization of the BCS state?
Hope this helps, and if you still have trouble let me know.
thanks. i am new here, please excuse my latex typing if there is error, i am not used to this:
we have:
|\psi&gt;=\prod_k [u_k + v_k b*]|0&gt;
i want to prove
&lt;\psi |\psi&gt;=1
i do the product but still cannot get rid of b and b* terms. is there an algerbraic trick there? thanks.
btw does anyone know why whenever i open a thread the screen keeps on scrolling down to the bottom page until the download finishes? is something wrong with my browser? or is it normal for this website?
Each of those factors adds (or removes, in the case of the adjoint) an even number of electrons: zero for the u_k part and two for the v_k part. Because all the states are different, any two of those factors can be exchanged since each such exchange involves an even number of fermion exchanges i.e. (-1)^2 = 1. The exception to this rule is when a factor meets its adjoint. If you call f_k = u_k + v_k b^+_k, then the normalization condition boils down to a bunch of terms like f^+_k f_k , and by exchanging such terms (see above) you should be able to evaluate them easily using the special properties of the vacuum state.
Alternatively, (well, actually it's much the same thing), you could show that the state |1 \rangle \equiv b^{\dagger} |0 \rangle is orthonormal to the vacuum state, given that the sum of the squares adds to 1.
is [b,b*]=1-ndown-nup ?
then we have bb* - b*b = 1 -ndown - nup
so
bb* = b*b + 1 - ndown - nup
and b|0> = 0 so b*b terms dissapear?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
