Is there any IR sensor that can differentiate color in the market at low cost?
IR sensors cannot differentiate colors as they operate outside the visible spectrum, detecting different frequencies instead. While they can provide information about the thermal state of objects, such as a red hot steel rod versus a white hot one, they do not convey color information in the traditional sense. False color IR images can be created by assigning colors to specific IR frequency ranges, but this is not the same as true color differentiation. For visible light applications, color sensors like the TCS3414 can accurately measure color chromaticity and intensity. Overall, while there are sensors for different applications, true color differentiation in IR is not feasible.
kloong
Where can i get the datasheet?
thanks.
I am not sure I understand the question. You can't talk about "colour" in the case of IR since the wavelength are -by definition- outside the visible spectrum (on the red side, hence infra-red).
But if you by "colour" simply mean different frequencies, then yes there are. Although it obviously depends on which wavelength you need. I believe one common way of doing this is to use several (wideband) diodes of the same type, but put different types of filters in front of them.
IR sensors operate in the infrared spectrum while "colors" are defined in the visible spectrum. A red hot steel rod will emit a different IR spectrum than a white hot steel rod and an inference can be made from the IR signal as to what the "color" of the rod might be to the human eye... but this is a special case.
IR sensors will detect radiation emitted by an object or reflected by an object. But in neither case does the detected radiation contain "color" information.
A "false color" IR image on the other hand, as f95toli has said, is created by the arbitrary assignment of colors to particular ranges of IR frequencies or intensities.
See;
http://www.maxmax.com/false_color_ir.htm
http://en.wikipedia.org/wiki/Infrared_photography
http://dimagemaker.com/2009/05/03/false-color-infrared-images-with-the-xdp-filter/
Yes, there are colour sensors on the market which work in the visible.
The TCS3414 digital colour sensor is designed to accurately derive the colour chromaticity and illuminance (intensity) of ambient light, providing a digital output with 16-bit resolution.
for more info check out
http://www.pacer.co.uk/jkcm/Products/Categories/Visible+and+Ambient+Light+Sensors/Colour+Sensors
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
