Is this all correct? (more bl dy vectors)
  • Thread starter Thread starter Dr Zoidburg
    Vectors
The discussion revolves around verifying the correctness of calculations related to a line equation and points in three-dimensional space. The participant confirms that point Q (2,1,2) does not lie on line P, as substituting the coordinates into the line's equation yields inconsistent results. The parametric equations for line P are established as x=2t-3, y=t, and z=t-1. The method to find point R, which is perpendicular to line P from point Q, involves using the dot product, leading to the conclusion that R's coordinates are (5/3, 7/3, 4/3). The conversation highlights the importance of correctly identifying vectors and emphasizes a simpler approach to solving the problem.
Dr Zoidburg
Is this all correct? (more bl**dy vectors!)
I hope these are right, but I have the nagging suspicion that they're not? Where have I gone wrong (if I have indeed gone wrong)?
line P has equation (x+3)/2 = y = z-1
(a) Show that point Q (2,1,2) does not lie on line P.
(b) Write down the parametric equations for the line.
(c) Use dot product properties to find the co-ords of point R which is on P, such that QR is perpendicular to P.
(a) sub (2,1,2) into the equation:
(2+3)/2 = 1 = 2-1
5/2 = 1 = 1
they don't equal, therefore point Q does not lie on line P.
Is it that simple, or do I need to use [v(P) = (-3,0,1) + t(2,1,1)] and the parametric equations such that x=2t-3=2, y=t=1 & z=t+1=2 and attempt a solution. Here it is inconsistent.
(b) parametric equations:
x=2t-3
y=t
z=t-1
(c) dot product:
let u = (2,1,2) and v=(-3,0,1)
u.v = (2 1 2).(-3 0 1) |i 2 -3 |
= det |j 1 0 | = i - 8j + 3k
|k 2 1 |
point R = (1, -8, 3).
again, I feel I've skipped a step here, but it's 11.30pm and I'm too tired to think any further!
many thanks in advance! I'll be checking again in the am.
(2+3)/2 = 1 = 2-1
5/2 = 1 = 1
Yes, it really is that simple!
x=2t-3
y=t
z=t-1
I presume you just set (x+3)/2 = y = z-1= t. Yes, that's correct.
(c) dot product
|k 2 1 |
u= (2 1 2) is the "position vector" of Q but where did you get (-3 0 1)? It is NOT the direction vector of P, which is (2, 1, 1). It is the position vector of a point on the line (when t= 0) but that is pretty much an arbitrary vector. In fact, it is easy to check that you "R" does not even satisfy the equations to lie on P!
I would have done this differently. Let R be the point (x, y, z)= (2t- 3, t, t-1), on P. Then the vector from Q to R is given by (2t-3- 2, t- 1, t-1- 2)= (2t- 5, t-1, t- 3). The line from R to Q will be perpendicular to P as long as that vector is perpendicular to the direction vector of P: we must have (2t-5, t-1, t-3)\cdot(2, 1, 1)= 0. That gives 4t- 10+ t- 1+ t- 3= 0 or 6t= 14. t= 14/6= 7/3. Putting that back into the equations for R, R= (5/3, 7/3, 4/3).
As a check on the arithmetic, the vector from Q to R is (4/3- 2, 7/3- 1, 4/3- 2)= (-1/3, 4/3, -2/3). It's dot product with (2, 1, 1) is -2/3+ 4/3- 2/3= 0.
thanks a lot for that.
I have this problem of always thinking the solution has to be more complex than it appears to be!
I really must go out and buy another Occam's razor. Mine's obviously too blunt and ain't working as well as it should.
very minor quibble here: shouldn't that 4/3 be 5/3 ? :wink:
Yes, of course it should.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
