Is this angular momentum question correct?
The discussion centers on calculating the angular speed (ω) of a system where a ball collides with a pole on a center pivot. The initial angular momentum of the ball is expressed as L = -d/2 * m * v, where m is the mass of the ball, d is the length of the pole, and v is the speed of the ball before the collision. The final angular momentum is derived from the equation L = I * ω, where I is the total moment of inertia, calculated as I = mr² + (ML²)/12. The rearranged formula for angular speed is ω = [-d/2 * m * v] / [mr² + (ML²)/12], confirming the approach is correct assuming the velocity is perpendicular to the pole.
  • Understanding of angular momentum and its conservation principles
  • Familiarity with moment of inertia calculations
  • Knowledge of vector cross products in physics
  • Basic algebra for rearranging equations
  • Study the concept of angular momentum in detail, focusing on its mathematical formulation
  • Learn about the derivation and application of the moment of inertia for various shapes
  • Explore vector cross product operations and their significance in physics
  • Review conservation laws in mechanics, particularly momentum and energy
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts related to angular momentum and collisions.
Lachlan1
A ball traveling in a straight line, colides with the end of a pole on a centre pivot, ie, the pole initially has inertia given by equation (ML^2)/12.After the colision, the ball sticks to the pole and the two rotate together. What is needed to be found is the angular speed
use the variables m for mass of ball, d for length of pole, omega symbol for angular speed, v for speed of ball before colision.
cross product of vectors for ball initially are sued to generate the balls angular momentum.
so, angluar momentum=(displacement vector) *(momentum vector) = L = r*p
i take this as L=-d/2 *m*v
this is also angular momentum intital, as the conservation of momentum is used to calulate the resulting angular speed. the final angular momentum = inertia *omega
final inertia is equal to the sum of the two moment of inertias about the axis. this is
mr^2 + (ML^2)/12
using
-d/2 *m*v=(omega)(mr^2 + (ML^2)/12)
rearange to isolate omega results in
omega= [-d/2 *m*v]/[(mr^2) + (ML^2)/12]
is this right though? I am not sure I've done the cross product correctly.
Assuming that the velocity of the ball is perpendicular to the pole when it hits, it looks ok to me.
Though, you probably want to express r and L (in ML^2) in terms of d to avoid confusing yourself later (especially since you also used L to mean angular momentum).
yeah, ok. thanks for your help
  • · Replies 17 ·
18K
