Is this constraint nonholonomic or not?
2 replies · 2K views
qwerfdsazxcv
I really want to know whether this equation is nonholonomic or not.
(As far as I know, Nonholonomic constraint has a term of velocity and do non-integrable. But this formula does not dependent on a path, because it is a total differential form.)
It is nonholonomic, for the reason you gave. Note that the second part of the constraint ##df=\frac{\partial f}{\partial q}dq + \frac{\partial f}{\partial q'}dq'+\frac{\partial f}{\partial t}dt=0## is redundant, as it follows from the first constraint.
Sorry for digging up old story but the correct answer on OP's question is as follows: it depends on the function ##f##. For example, if ##f=\dot x## then the constraint is holonomic; if ##f=\dot x+y\dot z## the the constraint is nonholonomic.
