Calculating Speed Needed to Break a Parachute with Nylon
  • Thread starter Thread starter oscarwyatt
The discussion focuses on calculating the speed required to break a nylon parachute, with key assumptions including a perfect dome shape and ignoring the weight of the person. The ultimate strength of nylon is noted as 75 MPa, leading to a calculation that a parachute would break under a weight of 15 tonnes. The drag force equation is rearranged to determine the velocity at which this force exceeds the parachute's strength. The final calculation indicates that the parachute would break at a speed of 52.27 m/s or faster. Overall, the calculations presented appear accurate, with a suggestion to verify the equation's consistency with the initial assumptions.
oscarwyatt
Hi,
I have to do a presentation at school and I've chosen to talk about nylon for parachutes. We have to do a calculation and although I've done it, I am a bit worried if its correct or if there's something I've missed, its rather important so I was wondering if anybody could see any problems with it. Briefly explained, the idea is to find out how fast you would have to be falling to make a parachute break, first by calculating how much weight would make a parachute break and then converting this to force and using an equation.
Its based on these assumptions:
- The parachute is a perfect dome
- The straps on the parachute will not break
- The person can be falling at any speed, we will assume his terminal resistance is infinite
- The area of the parachute is 60m2
- We will ignore the weight of the person and that of the parachute itself
- The parachute is formed from a single unbroken mould of a parachute
The ultimate strength of nylon is 75 Mpa – 7,500,000 kgm2
I think a parachute would be about 2 mm thick
Therefore: 15,000,000 = 15,000 kg
1000
The parachute canvas will break when a weight of 15 tonnes is applied
We need to find the velocity at which the drag force will exceed the strength of the parachute.
This can be done by rearranging the following equation:
FD = ½ densityofair Cd A v2
Or
Drag force = ½ x density of air x drag coefficient x area of the parachute x velocity2
To become:
drag force = velocity2
150,000 = velocity2
½ x 1.22 x 1.5 x 60
Therefore:
2,732.22 = velocity2
Therefore, the parachute would only break if you were traveling at 52.27m/s or faster
If anyone wants to see it as it is in the presentation (probably better idea) its http://www.rhphotography.co.uk/nylon.ppt"
Cheers
It looks like you did a good job on your presentation. Your calculations seem to be correct and I can't see any major errors. You may want to double-check the equation you used to make sure it is consistent with the assumptions you made, but other than that, it seems perfect.
