Can You Solve This Third Order Homogeneous Differential Equation?
  • Thread starter Thread starter Saladsamurai
    Diff eq
Saladsamurai
Is this diff eq solvable? !
Find the general solution to the third order homogeneous diff eq if one solution is known to be:
x^2e^{5x}
I was thinking of using reduction of order but I don't have the original equation!
Okay. Since it was given that the 3rd order diff eq is homogeneous, it is okay to assume that there is no particular solution to this, right?
And I can also assume that (m-5) is a factor of the characteristic equation. I am also assuming that it is a thrice repeated root, so y=c_1e^{5x}+c_2xe^{5x}+c_3x^2e^{5x}
I am not so confident in this, since it is all based on assumption. Any thoughts on the validity of this?
It might help a bit if you told us what the differential equation was.
Read the OP. It has not been given.
Assuming this is a linear homogeneous 3rd order diff eq with constant coefficients, then that is the case and the differential equation must be (D- 5)3y= y"'-15y"+ 75y'- 125y= 0. Of course, we were not told that.
So, as it stands, this problem has been worded incorrectly. That is what I thought. Thank you.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
