Is this ok with Polar coordinates?
The discussion centers on understanding the change in the unit vector in polar coordinates, specifically regarding the relationship between changes in unit vectors and angles. It clarifies that the differential change in the unit vector, denoted as de_r, is not a unit vector itself but represents the difference between two unit vectors. The explanation involves considering the squared magnitude of the difference between two infinitesimally close unit vectors and applying Taylor expansion for small angles. This approach effectively relates the change in the angle between the vectors to their differences. Overall, the discussion emphasizes the mathematical relationship between vector changes and angular differences in polar coordinates.
Azorspace
we have this diagram were it says that the change in the unit vector der equals in magnitude the change in the angle betwen the two unit vectors er. Could someone explain me why is this?
I include the diagram named Polar coordinates.
I don't think de_r is a unit vector. It is the difference between two unit vectors, but it itself is not a unit vector.
He doesn't say that de_r is a unit vector, it's the *change* in a unit vector.
But to answer the original question: yes, if you consider |e_1-e_2|^2 and use that e_1 is only a little (infinitesimally) different from e_2, e_1=e_2+\delta e, then you'll find what you need by comparing the answer to e_1\cdot e_2, and using how the angle between two vectors relates to the angle between the vectors, and Taylor expanding the cosine for small angles.
13K
