Is this the right integral set-up to find the volume?
  • Thread starter Thread starter Lo.Lee.Ta.
    Integral Volume
Lo.Lee.Ta.
1. Find volume between f(x) = x, g(x)= sin(sqrt(5x+3)), x=1, and x=2, when revolved around y=4.
2. Would it be correct to write the integral like this?
∫1 to 2 of [\pi(4 - sin(√(5x + 3))2 - \pi(4 - x)2]
I am using the washer method, and for the gap that's in the middle I usually think about it by saying r= inner curve - axis of rotation.
R= outer curve - axis of rotation
But in this case the axis of rotation is above the function, so would it be r= 4 - inner curve
and R= 4 - outer curve?
Thanks! :)
Please answer! :cry:
Yes, that's right. You ought to check that the curves do not cross within the range.
Yes, the inner radius should be 4 - inner curve and the outer radius should be 4 - outer curve. I think your setup is correct.
:D Thanks so much, haruspex and JPaquim! :D
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
