Discover the Isochoric Process: Calculating Temperature in a Sealed Tank
  • Thread starter Thread starter gothicsh
    Isochoric Process
The discussion focuses on calculating the temperature in a sealed tank during an isochoric process, where the volume remains constant. Initially, the tank contains air at 3.00 atm and 20.0°C. When cooled to a pressure of 1.00 atm, the temperature calculation was attempted using the formula P/T=const. The error identified was the need to express temperature in Kelvin rather than Celsius for accurate calculations. The correct approach emphasizes the importance of unit conversion in thermodynamic equations.
gothicsh
A 3.00-L tank contains air at 3.00 atm and 20.0 C. The tank is sealed and cooled until the pressure is 1.00 .
What is the temperature then in degrees Celsius? Assume that the volume of the tank is constant.
P/T=const
3/20=1/T, T=6.67 C
Why it's not right?
nvm, i got it
temp should be expressed in kelvin units not "C"
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
