Isolate Malonitrile:Extr w/ Ether, 3x100mL & 1x300mL
  • Thread starter Thread starter chiefy
    Extraction
The discussion revolves around the extraction of malonitrile from an aqueous solution using ether. The calculations show that when three 100 mL portions of ether are used, approximately 21.1 g of malonitrile can be recovered. For a single 300 mL ether extraction, the recovery is estimated at 18.0 g. The extraction ratios were calculated using the concentration of malonitrile in both ether and water, confirming the methodology is sound. Overall, the extraction process and calculations appear to be correct.
chiefy
Suppose a reaction mixture, when diluted with water, afforded 300mL of an aqueous solution of 30 g of the reaction product malonitrile,CH2(CN)2 which is to be isolated by extraction with ether. The solution of malonitrile in ether at room temperature is 20.0 g per 100 mL, and in water is 13.3 g per 100 mL. What weight of malonitrile would be recovered by extraction with (a) three 100 mL portions of ether; (b) one 300-mL portion of ether. Suggestion: For each extraction let x equal the weight extracted into the ether layer. In case (a) the concentration in the ether layer is x/100, and in the water layer is (30-x)/300; the ratio of the quantities is equal to k = 20/13.3.
Chemistry news on Phys.org
any ideas? anyone?
what's the problem? You've got most of what you need right here.
Is this right?
Well, is this right?
1) k = 20/13.3 = 1.5
x/30-x = .50
x = .5(30-x)
1.5x = 15
x = 10g in ether layer
30 – x = 20g in water layer
x = .5(20 – x)
x = 10 -.5x
1.5x = 10
x = 6.67
20 – x = 13.33
x/13.33 – x =.50
x = .50(13.33 – x)
x = 6.67 - .5x
x = 4.44
13.33 – 4.44 = 8.89
a) 21.1g = three 100-mL portions of ether
x/30-x =1.5
x=1.5(30-x)
x =45-1.5x
2.5x/2.5 =45/2.5
x = 18.0
b) 18.0 g = one 300-mL extraction of ether
yep everything seems correct
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
