ISS Toolbag visible with the naked eye now
  • Thread starter Thread starter Count Iblis
    Eye Iss
The ISS Toolbag is currently visible to the naked eye and is losing altitude rapidly, with reports indicating a descent rate of approximately 4 to 10 kilometers per day. Observations show it reached a magnitude of 8.6, appearing quite bright through a telescope. The Heavens-Above predictions were slightly inaccurate, being off by about 7 arcminutes in position and 20 seconds in timing. As it approaches a height of 170 km, it is expected to lose altitude more quickly, potentially leading to re-entry in just a few days. The toolbag has already fallen into the Pacific Ocean, narrowly missing visibility over regions like Mexico and Texas.
Astronomy news on Phys.org
Saw it with a telescope; it was magnitude 8.6, but appeared remarkably bright. The Heavens-Above prediction was about 7 arcminutes off in position and 20 seconds off in time.
Count Iblis said:
It's a few days before re-entry now:
http://heavens-above.com/PassSummary.aspx?satid=33442&lat=0&lng=0&loc=Unspecified&alt=0&tz=CET
It is losing height at a rate of about 10 km per day and when it comes below 170 km it will lose that amount of height every hour.
Exactly where do you get the number 10 for kilometers rate of fall per day? I have recorded the numbers almost daily since last November and made a graph recently. Even now it is falling at about 4 km per day. I have read that 200 km is a height where it will decay rapidly and you may be right that 170 km could be the end. Anyhow it should be soon.
Yes, I was wrong by about a factor 2. I think the Heavens-Above website a few days ago was a bit behind updating the height, skipping one day, giving the false impression that the descent rate had increased a lot.
The toolbag has dropped in the Pacific. Had it dropped just a little later, it would have been visible over Mexico and Texas.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
