Naming Organic Compounds: IUPAC Naming
In summary, the conversation discusses the IUPAC naming of a compound and a question about hydrogen bonding. The speakers are unsure if 3-bromo-1-chlorobutane or 2-bromo-4-chlorobutane is the correct name for the compound based on the numbering of carbon atoms. They also mention that functional groups should be named in alphabetical order and to the lowest sum.
no name
48
IUPAC naming!
Hey folks,
I just wonder how would you name this compound
CH3CHBrCH2ClCH2
is it 3- Bromo -1- chloro butane
or 2- bromo 4- chloro butane
another question : does CH3OCH3 form a hydrogene bond or not?
Any help would be greatly appreciated
You need to show your work.
What do you think the answers are and why?
well actaually i did the work ... and i am confused between the answers that i wrote ... wut i did is numbered the carbon atoms ... well i can number them in two different ways ..one where i will get the bromo on the 2nd atom and the chloro on the forth atom , and the other way is to number them where the bromo on the 3rd atom and the chloro on the first .. my question is which of numbering is correct .. ?
If I remember correctly, The nomenclature in which the functional groups get the lowest sum is to be used. Also, you should follow alphabetical order while naming them.
I am not too sure on this, so if I can get conformation, it would be nice.
I don't know if its a bit late but think about it.
IUPAC names it in alpha order and to the lowest sum.
Your compound looks like this:
-C-C-C-C-
Br Cl
Which would you think it looks like? From my perspective, it looks 3-bromo-1-chlorobutane.
Related to Naming Organic Compounds: IUPAC Naming
What is IUPAC naming?
IUPAC (International Union of Pure and Applied Chemistry) naming is a standardized system used to name organic compounds. It follows a set of rules to ensure that every compound has a unique name that accurately describes its structure and composition.
Why is IUPAC naming important?
IUPAC naming is important because it allows scientists and researchers to communicate effectively and accurately about different organic compounds. It also helps in identifying and categorizing compounds based on their names, making it easier to study and understand their properties and reactions.
What are the basic principles of IUPAC naming?
The basic principles of IUPAC naming include identifying the longest carbon chain in the molecule, numbering the carbons in the chain, and adding prefixes and suffixes to indicate the functional groups present. It also follows a priority system for naming functional groups and includes rules for handling multiple functional groups and substituents.
What are some common mistakes to avoid in IUPAC naming?
Some common mistakes to avoid in IUPAC naming include not numbering the carbons correctly, not using prefixes and suffixes accurately, and not following the correct priority system for functional groups. It is also important to use proper punctuation and spacing in the compound name.
Are there any exceptions to the rules of IUPAC naming?
Yes, there are some exceptions to the rules of IUPAC naming. For example, compounds with common names or historical names may not follow the standard IUPAC naming rules. Additionally, some compounds may have alternative names or multiple acceptable names. It is important to refer to the most recent version of the IUPAC guidelines for accurate naming.
12K
  • Chemistry
