I've got to find things out about these pendulums
  • Thread starter Thread starter thear
The discussion focuses on a pendulum problem where a bob starts swinging from a height of 0.3000 m, losing 1.00% of its energy due to friction with each swing. Participants are encouraged to determine the potential energy (PE) at various heights after each swing to find the maximum height after the fourth swing. The initial potential energy is calculated based on the starting height, and subsequent heights must account for the energy lost in each swing. The conversation emphasizes the importance of breaking down the problem step by step to arrive at a solution. Understanding the relationship between potential energy and height is crucial for solving this type of physics problem.
thear
The pendulum is started swinging from a height of 0.3000 m above its rest position and allowed to swing freely back and forth. If 1.00% of the bob's energy is lost due to friction each swing, to what maximum height will the bob swing at the end of its fourth swing?
I cannot even begin to think of any
h=0.3000m
energy lost=1.00%/swing
max h=?
PEi + KEi = PEf + KEf + HE
h=0.3000m
max h=?
Welcome to the PF.
What is the equation for the PE of the pendulum as a function of height? What is the initial PE? What is the PE after the 1st swing? After the 2nd, after the 3rd, after the 4th? And so what is the height after the 4th swing?
Try talking problems like this through, and you will be able to at least show an attempt at a solution when you post the problems here...
