J.J. Thomson's m/e Experiment, Help
  • Thread starter Thread starter SuicideSteve
    Experiment
SuicideSteve
In Thomson's experimental determination of the ratio m/e of the mass to the charge of an electron, in which the electrons were subjected to an electric field of intensity E and a magnetic field of intensity H, the equations
m(d2x/dt2) + He(dy/dt) = Ee , m(d2y/dt2) - He(dx/dt) = 0 ,
were employed. If x=y=dx/dt=dy/dt=0 for t=0, show that the path is a cycloid whose parametric equations are:
x = {Em/H2e}(1 - cos([He/m]t))
y = {Em/H2e}([He/m]t - sin([He/m]t))
I have solved the differential equation by substituting 1 for the constants and come out with:
x = 1 - cost
y = t - sint
My problem is I can not figure out how to end up with the constants in the results.
Any help is greatly appreciated,
Thanks.
Steve.
m(d2x/dt2) + He(dy/dt) , m(d2y/dt2) - He(dx/dt) = 0 ,
x = 1 - cost
y = t - sint
Thanks.
Steve.
There is something wrong with your two differential equations, since an "E" appears in the stated solution but is not present in your DEs.
RGV
RGV
Sorry, fixed it.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
