Jacobian of the transformation
Niles
Hi
I wish to perform an integral of the form
<br /> \int_0^a {\int_0^b {f\left( {x - y} \right)dxdy} } <br />
What I do first is to define s := x-y, and ds = dx. Then we get
<br /> \int_0^a {\int_{-y}^{b-y} {f\left( {s} \right)dsdy} } <br />
Then I can define t := x+y, so dt = dy. Then I get
<br /> \int_{x}^{x+a} {\int_{-y}^{b-y} {f\left( {s} \right)dsdt} } <br />
I also have to multiply by 2, since it is the Jacobian of the transformation. But look at the limits: It doesn't seem to make things easier. Where am I going wrong?
Well, what, exactly do you want to do with that? You obviously can't "do" the integral without knowing what f is. However, your limits of integration in the final integral makes no sense. From the first form, since the limits of integration are constants, the integral does not depend on x or y but your last form for the integral clearly does.
The region of integration in the x,y plane is a rectangle with sides parallel to the x and y axes. In the u,v plane it is still a rectangle but with sides at 45 degrees to the u and v axes. Depending on what a and b are, you would probably have to divide the area into two separate integrations. In any case, I don't see that change of variable helping.
The reason why I am asking is because in my book they write the following
<br /> I = \int_0^a {dt_1 \int_0^a {dt_2 \,F(x,t_1 - t_2 )} } F(y,t_1 - t_2 ) = a\int_0^a {dt\,\,F(x,t)F(y, - t)} <br />
I cannot quite see how the second equality-sign comes about. I thought it came from substitution, as above.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
