Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #12,781
http://www.meti.go.jp/earthquake/nuclear/pdf/120328_02m.pdf Scattered debris survey plan (28 March 2012 mid-long term steering committee meeting)
[page 2]
Purpose
To perform a survey, checking whether debris spread by the hydrogen explosions are staying in the electric power plant premises.
Survey method
Explore regions of the premises starting at the center where units 1~4 are located, and going toward monitoring posts MP1~MP8. (As the first 500 m closest from center have already been explored and the debris there have been collected, they are excluded)
[page 3]
Definition of the debris that are the object of the survey
* Shape: solids (building rubble) like small stones or bigger that can be checked by visual observation
* Radioactivity, radiation dose: high radioactivity, high radiation dose objects that depart from background (BG)
Scattered debris determination standard
* When a debris is discovered, it is measured with a surveymeter (Geiger tube, ionization chamber). BG is also measured.
* If the measured value is higher than BG, the object is judged to be a scattered debris.
System
* Leader : 1 person, survey: 4 groups of 3 people (total 13 people)
Draft schedule
* 26 March 2012 ~30 March 2012 (2 April ~ 6 April is reserved in case of rain)
planned exposure
* Below 1 mSv/person.day
[page 4]
Fukushima Daiichi premises general layout map
Recording method
In case building debris scattered material is discovered, the discovery location is marked on a map. [Computing] the distance from units 2 and 3 reactor buildings with the premises layout map CAD system, the maximum scattering distance is measured and a map of the scattering area is generated.
[see also the map on page 4:]
red=plant boundary
yellow=scattered object survey directions
red dots=500 m range where scattering was confirmed
  • #12,782
http://www.meti.go.jp/earthquake/nuclear/pdf/120328_02x.pdf Results of survey of debris distribution in spent fuel pool, unit 4 (28 March 2012 mid-long term steering committee meeting)
[page 2/8]
1. Survey of debris distribution in unit 4 spent fuel pool
same as http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120312_01-e.pdf page 1
[page 3/8]
2. Outline of survey of debris distribution in unit 4 spent fuel pool
same as http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120312_01-e.pdf page 2
[page 4/8]
3. Result of survey of debris distribution in unit 4 spent fuel pool (19 ~ 21 March)
[page 5/8]
4. Outline of survey of debris at the bottom of unit 4's reactor
same as http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120312_01-e.pdf page 2 except "(if
necessary, we will use ROV)" which was deleted.
[page 6/8]
5. Result of the survey of debris at the bottom of unit 4's reactor
The diagram is the same as the one on http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120312_01-e.pdf page 4
[page 7/8]
6. New transparency check inside unit 4 spent fuel pool (20 March)
1. Checking method
At almost the same location as the last time (9 February), using the same camera, the same wire and marks, the visibility distance is measured.
2. result
Visibility was comparable with that of February 9. Therefore, we conclude that there
has been no change in the degree of transparency.
[The diagram does not require a translation as it is almost the same as the one on http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120210_03-e.pdf except that the man is now standing on the float, the fuel handling machine is not shown, and the spent fuel is not shown.]
[page 8/8]
7. Result of the transparency check inside unit 4 spent fuel pool (20 March)
same as http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120322_02-e.pdf
  • #12,783
http://www.meti.go.jp/earthquake/nuclear/pdf/120328_02d.pdf plant status (28 March 2012 mid-long term steering committee meeting) [only partial translation]
[page 1/6]
[A table displaying the plant parameters on 26 February and 27 March]
As unit 1, unit 2 and unit 3's PCV temperatures and RPV temperatures are around 25°C ~ 55°C (as of 27 March), there is no significant variation of RPV and PCV parameters such as the released radiation doses, and we judge that the cold shut down status is comprehensively maintained.
In order to maintain the measuring instruments' soundness in the future, while the surveillance with measuring instruments is continuing, a study toward diversification and implementation of alternative temperature surveillance means is under way.
[page 2/6]
[page 6/6]
  • #12,784
http://weather.goo.ne.jp/earthquake/12040123040.html There was a magnitude 5.9 earthquake off the Fukushima coast on 1 April 2012 at 23:04 JST. JMA seismic intensity scale "5 minus" was recorded at Tomioka and Naraha, Fukushima prefecture. There is no tsunami risk.
http://www3.nhk.or.jp/news/html/20120401/k10014131781000.html The NISA said that no problem was reported from Fukushima Daiichi or Daini (in consequence of this earthquake). Monitoring post radiations are stable.
  • #12,785
thebluestligh said:
Interesting scenes from TEPCO's video related to ocean monitoring of sea life in 20 km
Background plant looks like Hirono Power Plant (Fuel + Coal Plant) which is 10 Km South of Daini and 20 Km South of Daiichi; the 2 largest units on the middle are 1000 MWe and others are 600 MWe.
http://toolserver.org/~geohack/geoh...n&params=37_14_18_N_141_01_04_E_type:landmark
Dark smoke looks quite normal so Doom is off ;)
  • #12,786
The implementation of the common pipe to the stack from the SGTS and the hardened vent system includes a diving section just before the vent pipe enters the stack. It can be seen as a foo or a feature to have what is essentially a a water trap incorporated in such a system. On one hand it might provide additional scrubbing during a hardened vent procedure -- otoh it might also provide increased back-pressure, and increase the risk of diverting the flow of the vented gases back into the buildings through the SGTS system.
  • #12,787
http://www.tepco.co.jp/cc/press/betu12_j/images/120402j0101.pdf Report to NISA on units 1 ~ 3 thermometer reliability. (the NISA requested Tepco to write a report once a month) : some of the thermometers not previously evaluated were found to be usable, and some were found to be broken. Some thermometers that were not connected to a digital recorder have been connnected to a digital recorder.
According to the plot on page 126, unit 2's 69 TE-16-114L#2 RPV BELLOWS SEAL AREA, newly connected to a digital recorder (on 8 March 2012) reached 100°C on 19 March 2012. (but it is not marked as "broken"). TE-16-114L#1 is having a similar rising trend, reaching 83°C on 19 March 2012. I will be curious to see if those two are marked "broken" in next month's report.
  • #12,788
http://www3.nhk.or.jp/news/html/20120403/k10014177241000.html Because strong winds of 18 metres [per second] are expected, outdoor work with cranes is suspended at Fukushima Daiichi on 3 April afternoon. Crane arms have been made shorter. Sheets covering debris have been reinforced with weights and ropes.
  • #12,789
About 40mph, for those of us counting on our fingers and toes.
  • #12,790
http://sankei.jp.msn.com/region/news/120403/fks12040320560003-n1.htm Unit 1's cover is designed to withstand winds up to 25 m/s. According to Tepco, in the case of winds stronger than the limit for unit 1's cover, the cover could be totally displaced by the wind and hit the building, but it was designed so that the load would be distributed and the building would not collapse or be damaged.
  • #12,791
Isn't that only Beaufort 10?
What's with the occasional typhoon? According to wikipedia, a typhoon's a storm with wind speeds of at least 118 km/h+ - which's 33.8 m/s. Everything below is a "severe tropical storm" or less. So even the weakest typhoon would already overstrain the construction by 35%.
Isn't Japan a country which's being hit by typhoons fairly often? Wasn't there a typhoon hitting Fukushima last year? So how big are the chances for the construction of being exposed to wind speeds it wasn't designed for?
  • #12,792
I can't seem to find open-source analysis. Here's an extended abstract of some research paper:
http://ams.confex.com/ams/pdfpapers/137995.pdf
  • #12,793
  • #12,794
MadderDoc said:
Could it be an effect of continuing fuel damage?
Well, some small proportion of the fuel fissions spontaneously, no? Same story as with the earlier detection of Iodine and Xenon.
  • #12,795
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120405/1450_12ton.html At 1:50 AM on 5 April it was found that water was leaking from a pipe connected to the tanks where the water is stored after removing cesium. The leak stopped at 02:20 AM after closing a valve. It is thought that much of the 12 tons of water that leaked and include high concentrated strontium, have flowed to the sea. Tepco is investigating why the pipe junction failed and the quantity that flowed to the sea.
http://www.tepco.co.jp/nu/fukushima-np/images/handouts_120405_03-j.pdf diagram, pictures about this leak
  • #12,796
Is there any detailed listing of all the radionuclides and their concentrations in the water from the reactor buildings available? I haven't seen one yet.
  • #12,797
A comparison of survey photos of the top of fuel racks in the spent fuel pool of unit 4, with the IAEA's map of assembly decay heat activities in the pool strongly suggests that the precipitation that has formed on top of the tie plates has been shaped by the magnitude of the decay heat of each individual assembly. On top of low activity assemblies, a uniform layer appears to have developed, with only few perforations over the water tubes. On higher activity assemblies a similar layer appears to have formed, but it tends to have been cracked up and/or blown away. Here illustrated with the comparison for rack no. 22:
A similar photo mount for rack no 09, and the original IAEA activity map of the racks are attached (as shown in this map, the racks are numbered from 00 upwards, proceeding from the lower left to the upper right).
  • #12,798
This make sense. Hotter assemblies have induced thermals that carry away the lighter silt that has settled on them.
  • #12,799
Yeah. While on the colder assemblies those thermals were weaker, so a layer of silt could well settle on them. Under the hypothesis that what we see is the sole result of preferential sedimentation on colder parts , we would predict the rack frames and the number tags on the racks to be all covered by silt, wouldn't we?
  • #12,800
Hello,
Would you be so kind as to provide links to the source documents where you found the photos and the "IAEA map of assembly" ?
  • #12,801
tsutsuji said:
Hello,
The photos are cropped frames from the Tepco survey video at
http://tepco.webcdn.stream.ne.jp/www11/tepco/download/120322_01j.zip
The map of assembly activities is cropped from the document "DOE Response to Fukushima Dai-ichi Accident"
which is included in these transcripts from the US DOE ACRS subcommittee on Fukushima May 26 2011 meeting (the map is on page 188 of those transcripts)
http://pbadupws.nrc.gov/docs/ML1114/ML11147A075.pdf
It must have been just my inference from recollection, that DOE had got the information on the Unit 4 SFP heat generation distribution via the IAEA, and I may be totally wrong, sorry. The document itself says nothing about how the data has been sourced. The original source for such detail of information must of course have been Tepco.
  • #12,802
Thanks. I had guessed the pictures were from Tepco's videos, but I was not aware about that DOE document.
  • #12,803
New and quite exciting photos from the spent fuel pool of unit 3
http://photo.tepco.co.jp/en/date/2012/201204-e/120413-01e.html
Pictures are taken close to the cask transfer area, they show upright standing fuel racks, and ..
a fine close up view of an end piece from the rail foot of the bridge that carried the fuel handling machine.
(Here seen compared to a Quince photo of the foot of the quite similar FHM bridge of unit 2
  • #12,804
MadderDoc said:
New and quite exciting photos from the spent fuel pool of unit 3...
Lol. I just came to post a link to that Tepco release. Great identity spot Maddder! More of you're non-stop top-notch analysis!
I seem to recall just a few weeks ago someone here called that the refueling crane simply fell into the pool (it wasn't blown to kingdom come) based on clues in a photo, but that least-extraordinary thesis was not too well received.
Here's a video clip of what clearly appears to be part of the refueling crane, I suspect it's the upper deck of the trolley. It's also the same object I posted previously, suggesting it looks like the trolley deck.
Here's a video expressing skepticism that the Unit-3 fuel pool exploded, which imo is further supported by the release of photos of fuel racks in SFP3. I think the Unit-3 explosion had nothing to do with the fuel pool, and the pool only suffered from in-falling debris.
  • #12,805
indeed Arnie's pool criticality hypothesis would have steam-cleaned it and scattered the contents. Instead it's gor rebar pointing in.
Yet in the satellite photo 3 minutes post-explosion it looks to be steaming vigorously.
if that's a correct interpretation of photo it got a lot of heat from someplace.
Last spring I calculated ~10^18 neutrons into Keff of 0.95 would make a thousand pounds of steam
but couldn't come up with a path from core to SFP that doesn't go through a few tenth-value thicknesses of concrete...
so another scheme worthy of Wiley Coyote bit the dust.
  • #12,806
Nice catch MadderDoc, it was all but evident to identify the FHM Trolley skating. Looks like one find out FHM3... finally.
  • #12,807
Easy for that to be the wrong interpretation of that photo. Release could be from the edges of the reactor well plugs, not the pool.
  • #12,808
Thats largely my fault, but that's because I did not consider the round objects in the photo to be a great match for refuelling bridge pulleys. This didn't mean I ruled out the possibility that the refuelling thing was in the pool, I just didn't think the images presented were good enough evidence. Subsequently someone pointed out a related ladder and I did find a good video showing that, so despite my original negativity about the analysis I was not dead against it.
I hope that when we get to see the video things become slightly clearer, but debris of one sort or another in reactor 3 pool is clearly quite a big problem.
  • #12,810
Yamanote said:
They also did some investigations on the integrity of unit 4:
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120413_04-e.pdf
Thanks. This is a follow-up of the February measurements. It is good that it is now translated into English.
tsutsuji said:
http://www.tepco.co.jp/nu/fukushima-np/roadmap/images/m120227_05-j.pdf On page 85/94 there are four measurements of the distance between the reactor well water level and the 5th floor's floor in four locations. The measurements show that the floor is horizontal. It looks like the old "unit 4 is leaning" theory is ruled out...
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120413/index.html (survey into unit 3 SFP) the camera was lowered by about 7 m underwater. It was confirmed that part of the fuel handling machine (35 tons) has fallen into the pool. No conspicuous fuel damage was seen on the pictures. As it is dark inside the pool, the photography was not good and only 4 pictures were publicly released. Tepco said "With today's survey we could not understand the details of the situation. We shall perform more surveys so that we can find out the debris distribution and the fuel status, so that we can study a safe fuel removing method."
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120413/1510_teishi.html The nitrogen injection system into units 1,2,3 was suspended this morning for 2 and a half hours shortly after 01:00 AM. It is the 4th time it happens since last month (it previously happened on 12 March, 4 April and 7 April). Tepco is investigating the causes. As a consequence, unit 1's PCV temperature rose by 5°C from 50°C to 55°C from 04:00 AM to 06:00 AM. There was a leak from a joint in unit 4's pool cooling system. 40 liters of water including radioactive substances leaked into the building. Tepco does not know when the pump can be restarted.
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
467K
21K
  • · Replies 763 ·
282K
  • · Replies 38 ·
16K
12K
