Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #13,831
a.ua. said:
But then it would be hydrogen only on the 5th floor.
However, the explosion was also on 4 and 3 floors.
You seem a bit confused. There is no simple way to tell where the hydrogen was and wasn't - you can only see the damage caused by the blast (which does indeed extend downwards as well as outwards).
  • #13,832
After taking a closer look at the Sandia National Labs report, I found a link inside it to an information portal established at Idaho National Labs.
https://fukushima.inl.gov/
From there, click the "Public" link and you can get access to other stuff such as this report.
https://fukushima.inl.gov/PDF/FDASIP-Ver-6.pdf
  • #13,833
From the INL portal.
"Enhanced Ex-Vessel Analysis for Fukushima Daiichi Unit 1:
Melt Spreading and Core-Concrete Interaction Analyses with MELTSPREAD and CORQUENCH"
https://fukushima.inl.gov/PDF/MELTSPREAD%20CORQUENCH%20Analysis%201F1%20ORNL_ANL%20Feb2013.pdf
  • #13,836
Joffan said:
Through the faint haze of translation, this seems like an excellent internal response from Tepco.
Excellent, you say. Have you read it? There's a lot of pious noise and nothing BUT reactive measures, based solely on what happened in this particular accident. They are preparing to weather another tsunami, not to improve safety overall. The next accident will again be a surprise that no-one could have predicted. Maybe a crane will make a nest in their new autocatalytic recombiner.
We thought it would have been difficult to explain that the current nuclear power station was completely safe if we had recognized that measures for handling severe accidents were necessary
So now it will be easy to explain that the NPPs are completely safe?
  • #13,837
Ok Zap, You have SO honed in on EXACTLY my problem. No two incidents EVER happen the same. They are concentrating on the last accident instead of the NEXT. BULLSEYE.
  • #13,838
Well to be fair, they do divide the response into two parts: "Direct measures based on [...] Accident" and "Measures to structural problems[...]". It's from the latter where one would expect to see changes in the safety culture of the company and new risk assessments. But it would be equally stupid not to learn the direct lessons from the accident. Especially as those direct lessons (spare high pressure pumps, better means to bring in external power and coolant supplies, more resilient power supply, more redundancy in lighting and communication...) can help if something completely different than a tsunami occurs.
  • #13,839
The objective is in simplest terms to move decay heat to a heat sink.
A. The science of that is not so difficult - reliable pumps and reliable power for them.
B. Human nature is complex. To get a committee(or a group of committees) to agree on how to go about achieving A is daunting.
That the TEPCO report speaks to both is positive IMHO.
  • #13,840
The NHK has another surprising story, dated 10 March 2013 :
http://www3.nhk.or.jp/news/genpatsu-fukushima/20130310/index.html : As specialists had suggested that part of the water injected by fire-engine had leaked somewhere, the NHK procured by itself the unit 3 piping drawings and conducted a detailed analysis together with some specialists.
As a result, it was found that there is a byroad starting between the fire-engine and the reactor, and there is a possibility that water runs through the byroad and leaks into another device which is not the reactor.
At the end of the byroad, there is a device called "condenser" which is used to generate electricity and transforms steam back into water. Normally, the pump that is located there on the way, is running, so that the water is kept back, so that it does not flow into the condenser.
However, as we tested in an experiment with the help of the specialists, it was found that in the case where the pump is down, the water flows through without stopping, and there is a high probability that the water leaked during the Fukushima accident as all electric power had been lost.
This experiment result is corroborated by a press conference held by Tepco immediately after the accident, where Tepco indicated that at that time, unit 3's condenser was in a full-of-water status which cannot happen in normal time.
Furthermore, when unit 3's water flow generated by fire-engine injection is experimentally reconstructed and when that experimental result in used by specialists in a simulation, they find that 55% of the water volume leaks out instead of being injected into the reactor, and they conclude that this leaked amount is sufficient to explain why the meltdown could not be averted.
On the other hand, they conclude that if the leaked amount had been 25% or less, the meltdown could have been averted.
After the accident, fire-engines have been installed as a safety measure at every nuclear power plant in the country, but more than two years after the accident, what is emerging is that sufficient verifications have not been carried out about how certain it is that the water will enter the reactor.
According to Hosei University visiting professor Hiroshi Miyano, "the job is not finished after fire-pumps are installed, and it is meaningless if one does not check if a sufficient amount of water for cooling the nuclear fuel is coming into the reactor. The verifications made after the accident have not been sufficient."
http://www3.nhk.or.jp/daily/english/20130310_28.html (NHK World English version)
  • #13,841
Welcome back, Tsutsuji-san, your insightful comments have been missed!
Once again, this report underlines the need for practical training.
Theoretical studies of what happens in the event of a complete power failure may miss major complexities in the real world system that only become apparent when actually exercised.
Is there any program in Japan to actively train operators to deal with such a complete station black-out contingency?
  • #13,842
Arrgh !
Usually there's a check valve at a pump discharge to prevent just that from happening..reverse flow when pump is off.
But check valves can stick partway open...
Big disasters are always a string of dominoes , little things individually until something pushes the first one over.
That's how "... the small thngs of the Earth confound the mighty".
Welcome back tsutsuji (finally i spelled it right ! )
  • #13,843
Sounds much better than response from almost every other country's nuclear industry, which 95% of the time boils down to "we checked our accident preparedness and it's just fine, we aren't like those stupid Japanese. Nothing needs to be done". Yeah right...
  • #13,844
Russian already invested tens of millions $ in the purchase of new mobile devices to transmit power and high-power pumps.
In Ukraine, not so well (we have less money), but the technique is bought .
And the most important exercise and a good knowledge of their own nuclear power plant.
  • #13,845
IRSN explaining the accident:
Nothing new, but everything already uncovered neatly packed together with animations. :)
  • #13,846
http://www3.nhk.or.jp/news/genpatsu-fukushima/20130318/index.html an electric power black out happened on 18 March before 7 PM at the seismic isolated building. After checking, it was found that some of the electric systems were down. The water injection into units 1,2,3 is not affected. However, the cooling of SFP 1, 3 and 4 has stopped. SFP temperatures are between 13.7 and 25 °C. Temperature rise is between 0.1 and 0.3 °C per hour, so that it would take at least 4 days to reach 65°C. Tepco is investigating the cause of the black out and intends to proceed to SFP cooling restart work in function of the investigation results. The nuclear power regulation agency said there was some trouble near a cable connected to a high power switchboard. Monitoring post values are stable. Tepco says it is sorry for being late to disclose the information, as a consequence that it took some time to check the situation.
  • #13,848
http://www3.nhk.or.jp/news/genpatsu-fukushima/20130319/index.html Unit 1 SFP cooling was recovered on 19 March shortly after 02:00 PM. Unit 4 SFP cooling was recovered by the implementation of measures such as connecting emergency power generators shortly after 04:00 PM.
The other cooling systems are expected to be recovered by 20 March 2013 08:00 AM.
unit 1,3,4 spent fuel pools and the common pool's cooling systems stopped on 18 March after 3 switchboards connecting to the outside electric power were down.
On 19 March the work to recover two of those swichboards was completed and unit 1 SFP cooling could be started again after a 19 hour long stop.
Unit 4 SFP cooling was restarted using a backup power generator used as an alternative to the remaining switchboard.
Unit 3 SFP cooling is expected to be restarted by around 19 March 08:00 PM, after switching to a different switchboard.
The common pool is expected to be restarted by around 20 March 08:00 AM.
As far as could be checked by visual examination, no damage is seen at the swichboards where the problem occurred, and Tepco is still investigating the causes.
SFP 4 temperature rose from 25°C to 30°C before the cooling was started again, so that the 65°C limit set by the regulation was not reached.
Tepco said it apologizes for causing people to worry as a result of these troubles and apologized again for having been about 3 hours late to publicly disclose the trouble.
http://www.tepco.co.jp/en/nu/fukushima-np/handouts/2013/images/handouts_130319_02-e.pdf Power Supply Facilities Failure at Fukushima Daiichi Nuclear Power Station [the title says "As of 4:30 PM on March 19", but it is more likely to be as of 3:30 PM, as they don't mention unit 4 SFP secondary system as being recovered]
http://www.tepco.co.jp/nu/fukushima-np/handouts/2013/images/handouts_130319_04-j.pdf unit 4 SFP cooling secondary system was recovered at 16:13 on 19 March.
  • #13,849
Possible cause for the blackout:
A rat may have short-circuited a switchboard.
Tokyo Electric Power Company says it has found burn marks on one of the power distribution boards that stopped working and brought to a halt cooling systems for spent-fuel pools at the damaged Fukushima Daiichi nuclear plant.
A small animal that appeared to be a rat was also found dead near the board. The company suspects the animal touched the terminal of the board and caused a short circuit.
http://www3.nhk.or.jp/daily/english/20130320_28.html
I'm at a loss for words...
  • #13,850
I don't see anything strange about it. Rats exist. They can crawl into all sorts of spaces.
  • #13,853
According to Tepco, the power blackout of Fukushima plant was caused by a mouse that came in the terminals to have caused a short circuit.
trying to switch the blame to a dead mouse, good luck with that Tepco, it wasn't a design flaw at all.
  • #13,854
That switchgear looks to have flashed over.
I suspect the culprit was one of that mouse's buddies. There should have been nothing left of him. 480 volt makes a loud "BOOM" when it flashes.
  • #13,855
Europe uses 220V as its standard voltage. I assure you from first hand experience that 220V electric shock doesn't do anything close to that.
  • #13,856
Strength damage also depends on the current.
I saw the burning copper thick wire at 36 volts.
And even a 12 volt battery can kill.
If they fall on you from above.:smile:
Europe uses 380V as its standard voltage.
  • #13,857
So does 440 volts and about 10 or more amps. I know from personal experience when a ground a hot line. There was a bright blue-white flash, my body went stiff, the wrench (I was using the wrench to close a switch that was supposed to be dead) I was holding flew out of my hand, I flew backwards against the wall behind me, and I could smell burning hair and skin. Needless to say, I felt like I'd been hit with a sledgehammer all over. It took me a few minutes to recover, at which point I got myself out there, back to the office, and told I was taking the rest of the day off.
  • #13,858
Sorry, the StandarD Voltage in Europe is 230/400V (D/FR/AUT/NL/DK)
  • #13,859
It is now. It wasn't always.
  • #13,860
since 1987
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
467K
21K
  • · Replies 763 ·
282K
  • · Replies 38 ·
16K
12K
