Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #2,701
TCups said:
Thanks again to tsustuji @post # 2680 for the IR images provided
https://www.physicsforums.com/showpost.php?p=3227707&postcount=2680
Yes, I am sure tsustuji san is interested in a bit more what Tepco and his government tell him.
There are more, I combined the history in three pdf files
when analysing, please be careful of reflected heat by the sun and on some images one can see the shadows of the buildings in the morning sun
To translate just select Japanese text and paste into translate.google.com
on more file for the 20th in the next post
  • #2,702
in continuation thermal image for the 20th march
  • #2,703
Is the fuel crane normally located in the top floor of the Unit ? In Unit 4 pics it is sitting on floor of second floor of blow out from top . Would this position be the bottom of spent fuel pool ?
  • #2,704
TCups said:
ADDENDUM:
Correction of initial error of interpretation on my part - the "ground activity is not from heat sources on the ground. There is a perspective error. The heat sources labeled "ground activity are from lower levels of the building. Also, remember, these images are in the IR spectrum, presumably, not the X-ray or gamma ray spectrum.
Look at attached image - you can see the shadow of the morning sun, so ground activity are sun reflecting of the side walls and other objects on the ground. this image from 30 march
  • #2,705
TCups said:
NEW THERMAL IMAGE ANALYSIS, UNIT 4
Thanks for the new images, tsutsuji @ post # 2680
Here are new thermal images (at least to me) of Bldg. 4. I presume the "hot" area to the right of the SFP is the open core of the reactor with residual radioactivity, and I hope this is normal.
Without,
http://i306.photobucket.com/albums/nn270/tcups/Picture41.png
and with my annotations.
http://i306.photobucket.com/albums/nn270/tcups/Picture42.png
ADDENDUM:
{open core of the reactor with residual radioactivity, and I hope this is normal.} I think the heat seen here is from fuel rods that where reported to have been blown out during explosion at Unit 4 . They reported that fuel rods where scattered in Unit 4.
  • #2,706
Ground heat will not show like that on a thermal camera . There is something there more than normal ground heat . They have reported that fuel rods in Unit 4 where scattered during explosion .
  • #2,707
Browse through the the pdf files in https://www.physicsforums.com/showpost.php?p=3228130&postcount=2716" and you will see exactly areas that are illuminated by the sun and areas in shadows and on cloudy days these areas are absent.
However, I agree to you there are heat sources on the roof of unit 4 that do not tie in with the SFP
  • #2,708
Upper arrow is pointing to where a gray mass was in a pic I posted . Showing a lot of heat there .
  • #2,709
This image of 29th March shows clearly area illuminated by sun, the shaddow unit 4 casts
But the the roof of unit4 has heat outside the SPF
  • #2,710
Can you cite the source of the report of fuel rods scattered in unit 4, please. Thanks.
  • #2,711
If Unit 3's massive explosion didn't weaken Unit 4 then Unit 4 must have been so preloaded with hydrogen that when it did explode it ballooned the roof and pulled the four corners inward (at least two of them). The panels blew out like designed but the super structure was forced up and inward.
  • #2,712
May i ask what exactly it is we can ascertain from these IR images?
  • #2,713
Jorge Stolfi said:
Re the damage of #4 and the piece of debris stuck into the roof:
Its part of the roof of Unit 4 that fell back down after explosion .​
Thanks, it makes sense. Presumably the roof was a concrete or tarmac sheet laid on top of the metal framework, that was lifted off by the explosion without damaging the latter.
But now that the "shot by reactor #3" theory is busted, I am left wondering at puzzling features of the damage on #4:
  1. The concrete walls of the upper floor, on the West and East sides, seem to have been pushed INWARDS against the concrete columns.
  2. The same concrete shell on the North side (facing #3) was peeled off the concrete columns but kept hanging from the top.
  3. The top edge of the North wall was bent INWARDS, whike the first horizontal concrete beam just below it was bent outwards.
  4. While that beam was damaged, the much weaker outre shell remained mostly in place.
Could go on, buy you get the idea.
Perhaps there was an explosion BELOW the topmost floor, and that created overpressure on the OUTSIDE of the walls of the top floor, pushing them in?
Unit 3 exploded on March 14th, 11:15am. There was an explosion at unit 4 on March 15th, ~6:00am that blew out two wall panels. This damage was shown in helicopter flyovers. There were attempts to spray water into the pool at this time I believe and two instances of fire were noted. Some time after this there must have been at least one more (larger) explosion to leave the building in it's current state. You can see blast driven debris trails and damage that exited from both units 3 (very obvious) and 4 (less obvious) in the hi-res aerial photos.
  • #2,714
Jorge Stolfi said:
I have plotted the data from the NISA/METI press relases:
http://www.ic.unicamp.br/~stolfi/EXPORT/projects/fukushima/plots/cur/Main.html
Hope it helps. All the best, --stolfi
Great stuff - thank you very much.
What I wonder about, is that drywell is pretty radiating in all 3, and in #1 the Torus is also quite hot.
Why is the Torus so active in #1 but not in #2 and #3?
  • #2,716
I want to clarify something with the IR images, although some might seem to show ground activity, that's mostly due to the variation in the measured temperature range, when the same color spectrum is used (rainbow in this case). So in one picture, green might correspond to 15deg, but in another to 30deg. Keeping that in mind, I don't see anything anomalous on the ground apart from slightly shiny objects (in the IR range). Another point is, because there is steam over the SFP's, the temperature readings will be affected (show lower values).
  • #2,717
Photos of the infamous "leak in the pit" from the METI press release 71 (2011-04-03-15:30) :http://www.meti.go.jp/press/2011/04/20110403002/20110403002-4.pdf"
  • #2,718
This http://www.whas11.com/home/Hopes-new-power-line-may-ease-Japan-nuclear-crisis-118105609.html" has the US claiming Unit 4 pool is dry. Company says no. This post has a slightly different picture of Unit 4 with no steam showing at all after the blast with the poster's own speculations.
  • #2,719
That is from 16 march - nearly 3 weeks old!
  • #2,720
Extreme heat radiating from that particular area that only nuclear decay could cause. Hopefully the area is surrounded by water as it cools down.
  • #2,721
Do you mean the two central panels on the North and South walls (3rd row from top)? Then the explosion was below the upper floor, right?
Or perhaps you mean two panels on the South wall, near the SE corner? (That is where the Green Machine can be seen, and some reports claim that the SFP is just below it.)
That is interesting. I haven't seen anyone mention a second explosion at #4.
  • #2,722
razzz said:
For reference, Wikipedia has a decent time lines and overall information combined together.
http://en.wikipedia.org/wiki/Fukushima_I_nuclear_accidents"
I looking for more details for the first hours and days.
When did the diesel generators fail? When did the batteries run out of power? When stopped the emergency cooling for each unit? When exactly did they start venting? etc. etc.
Some of that information (eg. about the diesel generators) is in the Japanese Wiki (try to translate by google)
http://ja.wikipedia.org/wiki/%E7%A6%8F%E5%B3%B6%E7%AC%AC%E4%B8%80%E5%8E%9F%E5%AD%90%E5%8A%9B%E7%99%BA%E9%9B%BB%E6%89%80%E4%BA%8B%E6%95%85%E3%81%AE%E7%B5%8C%E7%B7%AF"
Other information is still missing (batteries).
For me it is not clear what happened, especially whether the engineers always did the right things at the right times.
  • #2,723
I know that but the question is, who do you believe? Pools are dry and an explosion spreads fuel everywhere or fuel partially exposed with 'normal' hydrogen explosion.
It was a no win either way for if the pool was empty for any length of time and refilled by chopper or hose, then they had to create a blast by adding water on hot fuel rods. Low water in the pool, smaller explosion happens anyway.
  • #2,724
Thank you for the IR image btw , we now have evidence that the concrete slab on unit 3 is gone
  • #2,725
Browse thishttp://www.docstoc.com/docs/7522336...m=email&utm_campaign=109121477&utm_content=3"
  • #2,726
I believe it was the SE corner by the pool (first explosion). I have never seen documentation of other explosions - except the unmistakable evidence in the current aerial photos. I find this puzzling. It must have occurred at night, but the onsite workers must have heard it. Like the spike in offsite radiation on the 21st - clear evidence of serious change but no official explanation or mention. Adds to the sense that much more is known and suspected than has been publicly discussed.
  • #2,727
Bodge said:
"Tellurium 129 Presence Is Proof Of Inadvertent Recriticality At Fukushima"
That's the latest claim from Gunderson, via http://www.zerohedge.com/article/tellurium-129-presence-proof-inadvertent-recriticality-fukushima"
It has a 70 minute half life. Data collected 30.03.11
http://www.tepco.co.jp/en/press/corp-com/release/11033110-e.html
There is also a metastable isomer of this isotope, see http://nucleardata.nuclear.lu.se/nucleardata/toi/nuclide.asp?iZA=520429
It has a half-life of 33.6 days, and most of it (63 %) decays to the ground state by emitting a gamma. So the ground state is expected to be in the spectra. In steady state ("equilibrium"), it should be in the data with 63 % of the activity of the metastable isomer.
Its presence does not prove any recent criticality. It does not even point to recent criticality.
  • #2,728
Does anyone know where the vent from the drywell into upper containment should be? Or the vent for the wetwell? Could these vents which I understand fail open be the source of the steam.
I also wonder why the water pouring into the ocean via the crack isn't steaming hot. If the feed water temperatures are correct the water temperature exiting that crack should be close to boiling. Large amounts of water vapor should be visible especially with the low ambient temperatures.. I don't see it. I see relatively cold water being injected into the channel.
I think the drywell and wetwell are completely flooded in reactor 2 except for an ullage space and at a lower temperature then the sensors are reporting. Steam in an intact reactor vessel is venting into the wetwell and the water level is balanced by the steam pressure and the water injection pressure. Steam is going up the vent and colder injected water is exiting another path.
  • #2,730
TEPCO does not know where the contaminated water comes from:
http://www.saposjoint.net/Forum/viewtopic.php?f=66&t=2657&p=31585#p31585"
Tokyo Electric Power Co. used colored powder Monday to trace the source of highly radioactive water leaking into the sea near the troubled Fukushima Daiichi nuclear power plant, while mulling the use of silt-barriers in the sea to prevent the further spread of radiation.
The plant operator poured 13 kilograms of the powder into an underground trench to find the point from where radioactive water is leaking into the Pacific Ocean in front of the plant, after its attempt to block the leakage from a cracked seaside pit connected to the No. 2 reactor turbine building showed no effect so far.
Radioactive water has been filling up the basement of the No. 2 reactor turbine building and the tunnel-like trench connected to it. The powder was injected into the trench shortly after 7 a.m. but did not come out from the crack as of 11 a.m., according to the company officials.
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
467K
21K
  • · Replies 763 ·
282K
  • · Replies 38 ·
16K
12K
