Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #5,431
MadderDoc said:
I think perhaps this video has been shot with a camera slightly above the surface, with submersed lighting from the sides of the camera. The apparent visually disturbing thermal gradients may in fact be motion of the water surface, the camera is looking through.
As others have observed, we can see when the camera enters the water (at frames 35-40) and comes out again (150-155).
It is not the illumination that is waving, the rack shapes get visibly distorted and magnified. And I do not think it is salinity either; the flakes show vigorous convenction, so the salt and fresh waters must be well-mixed by now.
MadderDoc said:
It is clear that some of the stuff moving about is debris, but just as clear that some of them are bubbles.
Yes. Could they be steam? If the pool water near the surface is at 90 C, wouldn't steam bubbles condense before rising more than a few feet?
If they are not steam, what could it be? Too many and too late for disolved air. Hydrogen? Presumably, if the flow of water through an assembly is suffciently blocked at some point, a steam bubble will form below the block, and then fuel in that region can get arbitrarily hot.
MadderDoc said:
I think these 'bumps' must be for handling the racks. I am not sure that the bumps in rack no 2 and rack no 7 look different. They do look much alike to me.
Indeed. In your sharper picture the light curved spots in row 2 (lower) resolve into a row of handles like those in row 7, and separate round spots belonging to the top of the assemblies.
  • #5,432
fluutekies said:
extrapolated ~ 257 Bq/cm3 Cs-137 on 15-Mar-2011,
which is ~ 3 E+11 Bq or 0.3 TBq Cs-137 total in SFP#4
To be continued (calculation of mol or g Cs-137 for that decay and comparison against mol or g Cs-137 in undamaged fuel rods)
According to my calculations with t1/2 Cs-137 = 30.7 years, the decay function and Avogadro's number, an initial decay rate of 0.3 TBq Cs-137 corresponds with an amount of 7E-4 mol Cs-137 or 0.7 mmol, which is about "only" 100 mg Cs-137.
If this would be correct, not much of the initial inventory of Cs+ has been released into SFP#4.
  • #5,433
I found photo, i don't know if it was posted here before. It is unit #4 view from turbine building side, there is this "something" about here was so much discusion:
  • #5,435
fluutekies said:
Agree. Here my try for quantification of the leak of SFP4 based on Cs-isotopes:
Cs-137
93 Bq Cs-137/cm3 on 2011-04-28
55 Bq Cs-137/cm3 on 2011-04-13
59% Cs-137 remains in SFP after 15 days.
Erm.
The 'original' value is the lower, so the amount of Cs is increased by 69%.
Ps.: OK, sorry - the timeline is ok, the 55Bq is from 04.28.
  • #5,438
Cs decrease rate and TEPCOs theory of the broken gate to SFP#4
When calculating the leakage rate of the SFP#4 I get these formulas for the leakage rate r:
1. Refill at constant rate:
r1 = V/t*ln(C(t)/C(0))
2. Refill only once:
r2 = V/t*(C/C(0) - 1)
The truth is somewhere in between because TEPCO probably does a refill once or twice a day. But this does not really matter: r1 / r2 = 1.29.
What is more important: there is the volume V of the SFP in the formula. Now, TEPCO said that the gate between the SFP and the RPV has been destroyed. This would increase the effective volume we have to put into these formula.
With V = 1200 m3 we get a leakage rate of ~40m3/day. Adding ~70m3/day evaporation rate we get 110m3/day total loss rate which is consistent with the refill rate published by TEPCO.
But if we have to increase the volume V (I estimate a factor 3) we get much higher rates (120m3/day leakage rate + ~70m3/day evaporation rate = 190 m3/day total loss rate) which are no longer consistent with refill rate published by TEPCO.
  • #5,440
It was but with a lesser resolution. In my opinion this is the same structure , likely metalic that we are observing there.
  • #5,441
Rive said:
Erm.
You are right. I messed up the dates in the posting. Here again the source: http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110429e13.pdf I will edit the posting to avoid confusion. Edit: Not possible anymore. But the calculation is still valid.
  • #5,442
  • #5,443
What means by now? Each time they pour fresh water in, there's salinity difference.
You can just look at frames where the camera leaves the water. Instantly you see same green looking stuff (underwater things, still lit up) but a LOT more blurred and a LOT wavier. Obviously the camera is emerging from underwater, not the light.
  • #5,444
jlduh said:
The happiest news since a long time:
http://americasforum.org/archives/427
:biggrin:
Happy? I suppose that the police will know that hippies with geiger counters are on their way to their dealers.
  • #5,445
Yes, Thanks! So it seems that "Big Greenish Closet" is indeed the "Mysterious Green Box", which was toppled from the terrace and is now hanging from it by cables/metal/pipes/whatever.
In the ground-level photo, it appears that the Big Greenish Closet is not resting on the ground, rather it is suspended some distance above it. So its size may indeed match that of the Mysterious Box, which appears to be some 6 meters tall at least.
The question now is when the pictures were taken. In the photo posted by elektrownik I see what appears to be debris on the ground in front of the turbine building, so that may be after the tsunami. If the earthquake didn't topple the box, then what did? The explosion in #3? (However there is also a crane in elektrownik's photo, so perhaps the "debris" are ordinary mess from a construction site and the photo is from before the earthquake.)
"Always dispose of spent fuel rods properly"
--Tom Weller, Science made Stupid (1983)
  • #5,446
Dmytry said:
<..> I mean, on the left side of the top of the video, near middle.<..>
Right, I can see it now, that rack you are pointing to looks definitely damaged, and it does not appear to be from falling debris.
[URL]http://gyldengrisgaard.dk/fuku_docs/sfp4_rackdamage.bmp[/URL]
There's just too little waving in the video for the waves we see in the end. Does not look anything like look through waving water surface.
edit: also. This thing been cooled by salt water, and there's fresh water pouring in. Of course there will be a lot of 'shimmer' that is not from temperature differences, but from salinity differences
What I find hard to explain is the seemingly synchronous shimmering across large portions of the visual field of the camera. For this effect it would be necessary that whatever causes the shimmering, may it be heat or salinity transients, would have to be quite close to the camera. I wonder, do we have good reasons to believe there could be such sharp local eddies in the water? I do get the impression from the swirling debris in the water, that it is reasonably well-mixed -- otoh -- am I the only one that has felt this might be a 'fast motion' sequence, i.e. a sped up version of the original video in which many frames have been dropped? If so, the video would give an impression of a higher degree of mixing, than what's in reality. Dunno, perhaps this is an underwater camera.
  • #5,447
MadderDoc said:
{/QUOTE]
[URL]http://gyldengrisgaard.dk/fuku_docs/sfp4_rackdamage.bmp[/URL]What I find hard to explain is the seemingly synchronous shimmering across large portions of the visual field of the camera. For this effect it would be necessary that whatever causes the shimmering, may it be heat or salinity transients, would have to be quite close to the camera.
Makes sense to me. Hot water rises on one part of the pool, goes across some, goes down on other side. Fresh water stays on top.
I'm pretty sure it is... look at frame 155 (and 153...156) .
The frames 155,156 are how it looks when the camera is very close to surface of the pool and is blocking the light so you don't see reflections. The shimmer is definitely too small for waves.
edit: also look at frames 35-37 .
  • #5,448
Looks like some scaffold. Maybe for some repairs on the outer wall.
Maybe it was covered with something green like this :http://image.ec21.com/image/greennet/simg_GC03913493_CA03915980/PE_Nets_Scaffolding_Cover_Net_Debris_Net_Shade_Net.jpg
Such scaffold could disappear easily.
  • #5,449
It look like the shadow from the tower left side
  • #5,450
Look at the attached picture. Bottom. Quite damaged as well. Not compression artifacts, other frames also look bad.
I think there's a lot of damage to the bottom right of the camera, outside the view, that's where the bubbles seem to be coming from, and that's where heating must be for the flow to be directed up-left.
edit: whoops didnt attach.
  • #5,451
could be the shadow of the tower on something else.
but then again - i have clearly spotted winnie the pooh and a triangel-faced alien on the aftermath closeup photo of the same area, that was posted earlier in this thread ;-)
  • #5,452
March 12, 2011 ?
http://www.flickr.com/photos/beaconradio/5519735150/in/set-72157626118689013
highest resolution available: http://farm6.static.flickr.com/5014/5519735150_d55488e3c2_o.jpg
Looks to me that the photos were taken at the same occasion.
  • #5,453
Cainnech said:
March 12, 2011 ?
It's not the shadow for sure. Likely something related to the maintenance. But was it ab additional safety related system or not?
  • #5,454
From this picture it is obvious it is not shadow of the tower - shadow is visible in the different place.
Edit: beaten by ascot.
  • #5,456
Cainnech said:
March 12, 2011 ?
You can find the Foto here:
http://tupian.hudong.com/29105/25.html?prd=zutu_thumbs
  • #5,457
@Jorge Stolfi
Great work on the renderings!
At your post:
https://www.physicsforums.com/showpost.php?p=3275086&postcount=5393
You say/ask:
"However, the flanges connecting shroud and drywell seem to be rather massive things held together with a zillion heavy bolts. So I would expect that the walls of the drywell will rupture at some weld somewhere else, well before the bolts do. Is that correct?"
See page 5 of 7 in attached DOE-leakage study.pdf where it says;
"For the BWR Mark I -- a leak area of 35 sq in was estimated at -- 117 psig --. Most of this leak area (approximately 95%) is attributed to the drywell head which is predicted to unseat at a pressure of 27 psig."
The study described in the attached pdf "concentrated on identifying potential leakage paths that may occur prior to reaching currently reported containment shell capability pressures."
In other words, at a containment pressure [117 psig] which is much less than the design strength of the steel containment, the drywell head will unseat and leak.
@razzz
Is the above DOE-leakage study.pdf the report you remembered?
  • #5,458
Cainnech said:
March 12, 2011 ?
It certainly does. The photo must have been taken after the tsunami, and before the debris on the road by that orange crane was cleared. From the direction of sunlight, the time of day would appear to be in the morning, about 8 am. The clearness of the sunlight is inconsistent with the weather conditions in the morning of March 13th. This really leaves us with no other choice than to accept the date to which it is attributed, March 12th.
  • #5,459
[PLAIN]http://gyldengrisgaard.dk/fuku_docs/sfp4_rackdamage.bmp[/QUOTE]
Having stared at a few captures of this video for a while,I think people should be very careful when looking for damage to the racks themselves.
If I look carefully at the racks, then it seems that there are lugs/handles which protrude higher than the rest of the rack. They can be seen most clearly on the rack that is to the right of the image, and once noticed are also easy to spot for the rack we have a full view of in the middle. As they seem to always be on the third row of fuel slots from the edge, they would also be present in just the area you have pointed to with arrows, and if not taken account of may look like distortion to the racking.
Attached is an image with pairs of these circled.
  • #5,460
Good eye, Steve.
Now if only we could see what the rest of the SFP looks like. I'm sure TEPCO already knows...
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
471K
21K
  • · Replies 763 ·
284K
  • · Replies 38 ·
17K
12K
