Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #7,351
TCups said:
But even so, I am again somehow left with the feeling we are debating, by analogy, the size and trajectory of the bullet that was used to assassinate President Lincoln, not the result.
well, we are looking for the shootist and his rifle. good forensic practise to examine the bullet, no?
  • #7,352
The shootist was the primary containment. The rifle was the fuel transfer chute. The bullet was superheated steam and hydrogen gas with a lot of radioactive contamination. The target was the southeast corner of the upper floor of Building 3. The initial trajectory more lateral than vertical. The major explosion of the rest of the building followed, as did a large littoral explosion resulting from vaporized water. I have not been dissuaded from this theory by any evidence to the contrary posted here so far. Perhaps some may come to light that will make me reconsider. Perhaps not.
  • #7,353
Putting a condom on a nuke building is most fascinating.
Can you imagine a still fog becoming contaminated the longer it hangs around the Units and fallout contained in the water droplets (moisture) adheres to everything?
  • #7,354
I hope they are planning to make the condom's skeleton strong enough to support forms for pouring concrete at a later date. I think that is what will eventually have to happen at units 1, 2 and 3.
  • #7,355
clancy688 said:
Indeed, very interesting. Thank you very much for those documents. The first one is of special interest. I think it could explain what happened to Unit 2. Maybe there are hints as to what happened to Unit 3, but I didn't found any.
March 14th, 13:25 - RCIC fails in Unit 2
March 15th, 06:00 - Explosion in Unit 4
March 15th, 06:10 - Pressure drop in torus of Unit 2
March 15th, 06:20 - Explosive sound near torus of Unit 2
March 15th, 06:51 - Radiation dose at site boundary around main entrance exceeds limit value (11,9 mSv/h are measured some time later at the main gate)
March 15th, 12:00 - Large release starts and continues into Wednesday (I'm writing this down here because I'm trying to think out of the line. Unit 4 burned 4 hours earlier. I think nearly everybody thought that the radiation originated in Unit 4. But now TEPCO's giving us an explanation that the explosions and fires weren't connected to SFP #4 - so could it've come from Unit 2? An indication of a big containment and RPV breach?)
It was reported on March 14th / 15th that the fuel rods were completely uncovered, though I don't know for how long. If we look back how fast the core meltdown occurred in Unit 1, it's possible that there was also significant meltdown in Unit 2. So here comes my theory:
Some Corium pierced the RPV and got into contact with the quoted liner. Then it failed and there was a blowdown to the torus room.
I'm not sure if that means that the torus itself is damaged. If there's a blowdown from the primary containment to the torus room (where the torus is located), one could easily mistaken that as a torus damage. Especially, if you're unable to check out the situation because of high radiation readings.
Well even TEPCOs older data for reactor 2, which has not been revised in light of the reactor 1 water level realities, shows plenty of time for the core to melt. By 10:30 (or even an hour or so before this time) on the 14th water level is starting to drop, and drops below the top of the fuel by 17:12. Reactor pressure rises during this period. One of the torus CAMS picks up rather low levels of radiation during this period, but still more than zero. By 19:03 reactor pressure has fallen dramatically. By 22:00 a drywell CAMS is registering higher levels, and by 23:44 this level shoots up further, and a torus CAMS reading also shoots up. In the hours that followed the torus CAMS tends to decrease steadily, whilst the drywell CAMS increases over this period. At 05:30 on the 15th the torus still registers some pressure, but at 06:10 the pressure is listed as 0.00. Drywell pressure decreases at some point between 07:20 and the next reading at 11:42. And it looks like something happens between 13:00 and 15:25 because the reactor pressure falls a fair bit further between these 2 times, drywell CAMS reading shoots up by almost 3 times, torus CAMS rises a bit. The CAMS readings are recorded at their highest at 16:10 and then fall pretty much ever since.
OK so if they look at the above again with unit 1 water levels in mind, then we may be looking at the core starting to be uncovered sooner than 17:12 on the 14th. But I am not sure what this will tell us, since even a 17:12 start time gave more than 12 hours till the 06:10 event.
  • #7,356
intric8 said:
"Does anyone have any reliable info on the nuclear plants - the reports on the news seem garbled to me."
Weeks ago, someone mentioned the very first message in this thread (above), and how things have changed so little with Tepco that this comment is still very appropriate today.
Ringing truer than ever.
Well I never guessed when I wrote post #1 that we'd be here 2 months, 460+ pages and 7372 posts later and still know as little as we do.
  • #7,357
You need a source with enough water for your steam explosion. I doubt the pool was full to the brim and the reactor was venting because it was running out of coolant. Then you would need a large vacuum to draw in any water from the torus level with some heat to flash it or did the corium drop into the torus about that time? It would have had to eaten through many obstacles to get to that point. I don't think it is even designed for the corium to enter the torus.
  • #7,358
Unless they can make an encasement watertight, it seems kinda useless to dump sand and concrete on it.
  • #7,359
Interesting developments around reactor 3...
Source:http://www.spiegel.de/fotostrecke/fotostrecke-67871-8.html"
This image was published in German Spiegel magazine on May 11 and the translated picture text reads: "Photo from the SFP of Reactor 3".
Filled with rubble, not enough shown how high water level is.
Any fuel visible or completely covered with debris?
And, why are they adding huge quantities of hydrazine to the SPF cooling water now, as indicated by http://www.nisa.meti.go.jp/english/files/en20110510-1-1.pdf" ?
They didn't do (or mention) this before.
taken from image collection http://www.flickr.com/photos/xtcbz/sets/72157626687253144/with/5705937752/"
(Btw, very interesting Fukushima photo collection, many other interesting impressions there)
Constant heavy vapor emission on photo taken on May 10.
Appears to be quite more vapor than in the days immediately after the explosion. Why?
Containment slowly starting to develop more and more cracks while being flooded?
Yomiuri Shimbun translated by Google said:
15 TEPCO, the world prevent the Second Coming of the Unit 3 reactor at Fukushima Daiichi Nuclear Power Station, the reactor cooling water, on a dissolved boric acid to absorb neutrons, the same day to the reactor announced that the injection began.
Will be the No. 1 and 2, take the same measures.
Critical re-continuous fission phenomenon again. 1 - Unit 3 reactor pressure vessel was initially injected in the history of water for cooling, TEPCO was seen as the salt will absorb neutrons. The boric acid is dissolved in water cooling, since instead of fresh water from seawater cooling down because it is seen that the salinity.
Meanwhile, the pressure vessel of Unit 3 are top of the soaring temperatures. TEPCO "There is a possibility that water is leaking irrigation pipe as a" pipe from the 12th to add another 12 tonnes of water filling the pipe with two per clock. Has increased from 14 to 15 tons per clock injection volume, temperature of the top 24 in no time at 5:00 am on July 15 rose 46.5 degrees, was 297 degrees. TEPCO said, "is still not going well injection" sees.
( 02 minutes May 15, 2011 22:00 Yomiuri Shimbun)
This temperature increase by almost 50 degrees and the reintroduction of boron sounds serious to me.
If even Tepco talks about the possibility of re-criticality, then this sounds even more serious to me.
Are neutron current measurement instruments available to exclude the possibility of re-criticality, or have they been destroyed?
  • #7,360
  • #7,361
TCups said:
Uhhhh . . . If an explosion of superheated gas blasts out a large hole in the wall and roof of a concrete building, might it be reasonable to assume a quantity of dust and particulate would result from the mechanical damage, and that that dust and particulate, in the presence of heat and air (oxygen), might form a fireball? Somehow the picture of a sawdust cannon comes to mind.
or lycopodium powder:
Maybe this photo, taken on May 10, could give hints?
Look at the directional damages of the foreground building and the vent building, the stairs etc...
And, from this perspective also look the damages on bldg. #4...
  • #7,362
DSamsom said:
Tepco does not trust the other water levels either. Will try to check on reactor 2 and 3.
TEPCO says the gauges at the No.2 and 3 reactors might not be showing the actual water levels, and that the worst case is that the rods have melted down.
http://www3.nhk.or.jp/daily/english/16_04.html
For me, just after the release of the information that N°1 core melted in the first 16 hours, this way of wording things is just a new move from Tepco towards publicly admitting the evidence: 2 and 3 also melted, and we have now 3 melted cores.
No scientific proof (yet) of this, i admit, except some experience acquired in Tepco public relations policy and strategy based on observations of the last 2 months.
  • #7,363
Indeed, a comprehensive sarcophagus would involve much more than my simplified version. If there is really bedrock below the site, then it might be possible to pour concrete down to that bedrock, forming a bathtub. Above ground, the rest of the sarcophagus would be build on top of that foundation. The structure of the condom they are going to build now could be used in the future to support sarcophagus construction. By the time that day arrives, however, the costs of building a totally new sarcophagus will be a drop in the bucket compared to the cost of everything they will do between now and then. Multiple concentric shells, like a Russian matryoshka doll, might be desirable for defense-in-depth, as they say.
On the other hand, the challenges of building a secure containment like that in an area so prone to earthquakes might be too much to overcome.
  • #7,364
~kujala~ said:
The full theory for #4 includes also the explanation for the fires. Now TEPCO thinks that the explosion may have caused oil to catch fire
The matter of oil as a possible source of the explosion had been reported 5 days ago (on May 11) in this forum:
https://www.physicsforums.com/showpost.php?p=3295319&postcount=6580
And was one of the causes already being considered on a speculative basis a few weeks ago in this forum.
  • #7,365
ernal_student said:
The matter of oil as a possible source of the explosion had been reported on May 11 in this forum:
Wow, maybe the world should be informed of the real information, many theories have been true from people on this side of the pond...
  • #7,366
At least it means nobody should be surprised if that is what they find next.
I basically have the same view about TEPCO's approach to information control.
  • #7,367
etudiant said:
You are surely correct, a pure hydrogen explosion or combustion is a pretty low key event, in fact the flame is invisible, at least afaik.
So the orange fireball from reactor 3 strongly indicates substantial additional combustible/explosive material was involved. Normally flames are luminous because of white or red hot particles, generally of carbon, that are carried in the heated flow. Where these came from in this case is not yet clear.
Well, we know how the human eye reacts to a hydrogen flame, ie. you can't see it, unless it is VERY intense, then you can just see a little light. But, broadcast-grade TV cameras have dichroic beamsplitters that split the light into 3 color bands (plus luminance in some systems) for the image sensors. It is possible that the orange light is due to UV from the flame getting through to the sensors, and it wasn't actually orange in reality.
Concrete dust won't burn (as another poster suggests) except in pure oxygen. But, there are probably lots of lubes all over the plant, in pumps and gearboxes, and stored for maintenance crews. Possibly also flammable hydraulic fluids to operate various actuators. The hydrogen explosion could have crushed partially filled containers or broken hydraulic lines, releasing a spray of oils. There may have been other carbon-based materials around that could be easily ignited.
Jon
  • #7,368
TEPCO has previously mentioned that they were thinking of injecting some kind of soil hardener into the ground under the reactor buildings to stop water flow through the soil. Similar to what they did to stop the #2 subdrain leak into the ocean, I guess. (The plan involved digging some tunnels underneath from which to do the injection work, which doesn't sound very pleasant...) Don't know if they have abandoned that idea -- haven't seen it mentioned again.
  • #7,369
Your doubt is noted. But you make several assertions or presumptions not at all needed to support the theory I attempted to outline in Occamiam razor style - sharp and simple. No water from the torus pool is needed. No melting of the corium through the RPV is needed. No sudden criticality from the SFP fuel rods is needed. No one has presented any evidence that has convinced me otherwise, least of all that post.
  • #7,370
Hi, I uploaded some enhanced videos the the explosion and spent fuel ponds:
Explosion:
Spent Fuel Pool:
I might consider doing more, if the result might be as dramatic as the first enhancment.
BTW, does anyone have have a top view plan for the GE MK1; I found the sides here, but not the top. I might do a RhinoCAD 3d Rendering for Wikipedia.
  • #7,371
Let's hope they built directly on bedrock. The lady that stopped by saying Unit 4 was falling over and saying she heard the foundations missed bedrock by 130m or so, I hope not.
http://www.chuden.co.jp/english/initiatives/eini_nuclearpower/enuc_earthquakemeasures/eear_bedrock/index.html"
  • #7,372
Explosion:
Spent Fuel Pool:
Unit 1 blew the sides out and the roof collapsed as a whole almost intact.
Unit 3 looks worse every time I see it. In a longer time frame the head of the cloud is still turbulent rolling up even after the plume gets separated from it.
  • #7,373
jlduh said:
By the way, have these studes already been posted here?
1) VERY INTERESTING STUFF IN IT, details and schematics including failure modes
THE IMPACT OF BWR MK I PRIMARY CONTAINMENT FAILURE
DYNAMICS ON SECONDARY CONTAINMENT INTEGRITY
http://www.osti.gov/bridge/servlets/purl/5835351-nR29Hq/5835351.pdf
2) IDENTIFICATION AND ASSESSMENT OF BWR IN-VESSEL
SEVERE ACCIDENT MITIGATION STRATEGIES
http://www.iaea.org/inis/collection/NCLCollectionStore/_Public/24/072/24072657.pdf
Yes, the first one has been floating around this forum already, the second one has afaik only been in this forum indirectly mentioned in a link to another forum in this post by jim hardy https://www.physicsforums.com/showpost.php?p=3299953&postcount=7089 which was a reply to this post https://www.physicsforums.com/showpost.php?p=3299762&postcount=7073 (quoted again below for advertisement purposes :cool:).
Here is the direct link to the other forum for convenience again http://tickerforum.org/akcs-www?post=182121&page=314#new , the two long posts by Analog, there are some more interesting references linked to in there.
Just to advertise the rough idea from post #7073 and #7089 again (which indeed has been considered in one of those BWR studies, see Analog's post in the other forum)...
pdObq said:
However, what if there was recriticality in unit 3 reactor core? Would it be conceivable that after the fuel rods have been without sufficient cooling (above water level), they start heating up, melting away the control rods (borated steel, would it melt prior to the fuel pellets? [Yes, see below]), then they start injecting cooling water from outside, which cools the remains, but also acts as moderator. With control rods partly gone, the core suddenly goes critical, followed by essentially steam explosion within containment, which however, is not strong enough to destroy the drywell, but causes the spectacular explosion of unit 3 reactor building including gamma spike?
Rough melting points (from Wolfram Alpha):
Stainless Steel: 1440 degC
Zircalloy: 1850 degC
Uranium dioxide: 2180 degC (Wikipedia corium article says 2700-2800 degC for UO2, that would fit nicely with the new Tepco unit 1 data showing melting of the core)
Too bad, control roads seem to have the lowest one...
  • #7,374
They didn't for Fuku, it's "mudstone", bedrock is about 46m below the foundations. If it was bedrock, why would they have to permanently have groundwater pumps running to keep the local groundwater level below the lowest parts of the buildings?
EDIT: See this post for some references https://www.physicsforums.com/showpost.php?p=3291249&postcount=6263 . There was another post in response, trying to find it...
EDIT2: Ok, found it, a post by jlduh (https://www.physicsforums.com/showpost.php?p=3291411&postcount=6293) with a related article in japanese with a (not so readable) Google translation.
  • #7,375
TEPCO: No.4 blast due to hydrogen from No.3
From NHK.
http://www3.nhk.or.jp/daily/english/16_02.html
  • #7,376
Radioactivity at intake of No.3 reactor rises
Also from NHK
http://www3.nhk.or.jp/daily/english/16_06.html
  • #7,377
NHK is reporting that TEPCO will increase the amount of water injected into Reactor 1 from 8 to 10 tons per hour in a study of how to stabilize the reactor over the next 2 days. The belief is that if a certain level of water can be maintained, it may be possible to set up a cooling system that circulates water from the containment vessel to a heat exchanger and back to the reactor.
http://www3.nhk.or.jp/daily/english/15_14.html
Also, someone was talking about the live feed. As of 11:38 AM (local time), the feed shows local conditions at the plants to be sunny with a bit a haze. No visible steam from the plants.
  • #7,379
Not sure if this has been linked but it's a reasonably in depth comparison of differences between GE BWR mark 1 designs including emergency cooling systems. I.e. RCIC systems vs isolation condensors and which designs have what.
http://pbadupws.nrc.gov/docs/ML0230/ML023010606.pdf"
  • #7,380
Many thanks for to the people in the forum (Astronuc: thank you for personally answering my questions!). I have been following this forum for its' grounded scientific approach and analysis. It has helped a great deal in my decision making for my family who live in Tokyo and nearer to Fukushima.
Question re: measuring radioactive materials in the environment.
Why are there only reports showing levels of Cesium and Iodine (2 kinds)? Almost all of the releases by Tepco, for instance, only show these.
Again, many thanks.
49K
  • · Replies 41 ·
  • · Replies 2K ·
60
459K
20K
  • · Replies 763 ·
279K
  • · Replies 38 ·
16K
12K
