Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #8,401
Rive said:
I'm not sure that it's the liner of the pool.
If it is not the twisted sfp steel liner we see there in the foreground, what else could it be?
Back in the days of the big pixel-huntings there was several tries to match various floorplans of service floors with the photos but IIRC it's still undecided if the FHM is there on the south end of the pool (covered with rubble and beams from the roof).
Er, say what? It should be evident that not even a perfectly matched floor-plan could tell us where the FHM of unit 3 ended up during the explosion.
  • #8,402
I think it is a twisted ceiling beam that fell in the pool.
  • #8,403
NUCENG said:
Thank you very much!
On page 22 there are I131 and C137 source terms for Unit 1-3.
I131: 7,3*10^18 Bq (TEPCO said something about 8,1*10^19 Bq...)
Cs137: 6,8*10^17 Bq
On page 52, there's something interesting about H2 production under irradiation. But I don't quite understand what they want to tell us there...
  • #8,404
However, the twisted metal structure we see here in the foreground appears to be made of steel sheet-ware of an extension which we do not see in any of the structural elements of the roof.
  • #8,405
The Shika nuclear power plant, located in Western Japan was not hit by the March 11 quake and tsunami, but a number of measure are starting to be implemented to increase safety against tsunami and black out, as shown on the following diagrams and pictures : http://www.rikuden.co.jp/tousyataiou/attach/11042202.pdf
  • #8,406
Cs137: 6,8*10^17 Bq
Well, they rule out hydrogen production through chemical reaction with Zr, as fuel rods are not damaged enough to support that. Then they say that, basically, radiolysis in water vapor is efficient enough.
  • #8,407
AntonL said:
TEPCO: Tainted water disposal may cost $650mln
http://www3.nhk.or.jp/daily/english/28_03.html [...]
Do we know anything about the process?
Astronuc said:
Here are examples of radwaste treatments
http://www.wmsym.org/archives/2008/panels/56-2.pdf
The wastewater treatment for Fukushima according to the above presentation would involve in principle:
1. water/oil-separator
2. solids separation from the water-phase by decanter/centrifuges (see page 12)
3. remaining solids in the clear water are removed by membrane-filtration (page 13 "ultra-filtration")
4. cations and anions are bounded to an ion-exchange resin and collected (page 13, "demineralization")
5. regeneration of the resin delivers the cations and anions in concentrated solution for further processing (either evaporation or precipitation)
Unfortunately, the wastewater in Fukushima contains high amounts of NaCl from the sea water, which will consume a significant part of the ion-exchange capacity.
This process IMO is the best available technology available yet. The process can be fully continuous. The ion-exchange operation can be cycled by "merry-go-round" installations (venor-supplied-systems) e.g. a turn key unit consisting of the membrane-filtration, pH-buffer/control and coupled merry-go-round ion-exchange for a capacity of 7m3/h was offered 3 years ago for about 0.5-1MEuro. Space required: ~5x5m Much larger capacities are available and are used for (nonrad) inorganic wastewater treatment with metal-recovery applications.
  • #8,408
clancy688 said:
Let's assume all speculation about the leaning of Unit 4 are true. Then washing out of radioactivity isn't the biggest problem IMHO.
Why is Unit 4 leaning? I don't think that the hydrogen explosions are at fault, at least not entirely. Damage is only in the upper part of the building, but leaning suggests that there's something wrong with the foundation. So the Tsunami probably damaged the building's foundation or washed away / drenched the earth. Plus the cooling water which's further adding to the mud. Basically, the Unit is leaning because it's standing not on solid earth, but a muddy field.
But what happens if there's a typhoon coming, bringing heavy rainfalls with it? Could it further damage the underground to that point, that there's some kind of an Earth slide resulting in Unit 4 collapsing?
Weather forecasts for Fukushima (the town, didn't find anything for Okuma) predict 60 l/m² during the next two days.
Current rain radar for Japan, with precipitations in mm/h and animation:
http://www.jma.go.jp/en/radnowc/
  • #8,409
Hello,
here is something I just made. I took two snapshots from http://www.youtube.com/watch?v=95a8obR2GaE" video.
It's a 3D image and it is mostly a PoC. To see it you'll need red/blue glasses. Experiment by moving closer/farther from the screen when wearing the glasses.
If you can feed me with two images which were taken with a horizontal shift (e.g. a camera from a moving helicopter) then I can compose a 3D image.
Edit: you will want to view it full-screen as in this case size helps.
  • #8,410
Thanks. I did a little math...
I assumed the whole reactor area of Units 1-4 as a rectangle of 500 * 300 metres. That's 150000 sqm. Every mm precipitation results in 150 tons of additional water.
If there's a down pour of 60 l/m2 we get 9000 additional tons of water... is that enough to overspill the trenches? I don't know how much exactly those trenches and basements can hold, but I thought it were several ten thousand tons...
  • #8,411
Cooling system pumps stop at Fukushima plant's No. 5 unit
Headline from the news this morning in Japan. Local TV news is reporting that a cooling pump shut down. Temperature has risen to 87-88 C. TEPCO said that they are trying to switch to a different system.
At what temp should we be really worried?
  • #8,412
AntonL said:
It looks like a pre-cast construction method was used for the reactor building, at least for the upper part. That would explain why the columns got toppled that easily.
Re RB3 - I'm not able to see any evidence of pre-cast concrete constuction but an abundance of evidence that it was all cast in situ, the framework and the walls. I'm not able to see any reinfoced concrete section with a clean edge that would indicate a precast construction method.
What's in the image that makes you say that and\or what's your definition of pre cast concrete constuction?
  • #8,413
fluutekies said:
https://www.physicsforums.com/showpost.php?p=3267742&postcount=4952
The pdf document: http://www.osti.gov/bridge/servlets/purl/93598-H1kI7u/webviewable/93598.pdf
I've designed & operated an inorganic wastewater treatment unit for some years: the volumes are not the problem, but the chemical behavior of the components.
The principle is very simple: add chemicals which form (nearly) insoluble precipitates or form precipitates which adsorb or incorporate soluble ions.
In practice it will be a multi-stage process due to pH and redox-behavior. As the solubiltyproducts of the involved components are not zero, the purification is never perfect.
A typical treatment for e.g. Sr2+ would be addition of Na2SO4 to form "insoluble" SrSO4. If the solid formed is nano-crystallinic, a co-precipitation with Fe3+ or Al3+ will form a voluminous Al/Fe(OH)3-gel which incorporates the nano-particles. The gel is the flocculated with poly-acrylate for fast sedimentation.
The concentration of e.g. Sr2+ after this treatment will be 0.1-10 mg/L.
I don't think that this is good enough. The starting concentration of radioactive Sr is around 2e+05 Bq/ml (from here: http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110522_04-e.pdf). To calculate the concentration of Sr, where A(t) is the remaining amount and A0 is the starting amount, t is the time, and T is the half life,
A(t) = A0*2^(-t/T)
T = 29 years = 9e+08 sec
t = 1 sec
A(t) = 0.999999999238 * A0
To get 1 dps
A0 - A(t) = A0 - 0.999999999238 * A0 = 1
giving A0 = 1.3e+09 atoms of Sr-90
So, 2e+05 dps/ml * 1.3e+09 = 2.6e+14 atoms/ml = 2.6e+17 atoms/l,
2.6e+17 atoms/liter / 6e+23 = 4e-07 M
4e-07 M * 88 g/mole = 4e-05 g/liter
(I hope that I didn't make too many mistakes.)
That's less than your lowest estimate for Sr precipitation. Recovery of Sr by precipitation could be greatly improved by adding non-radioactive Sr to the solution. However, you've got to be absolutely certain about what you're doing, because this will preclude using any sort of selective capture of Sr if precipitation fails.
The low concentration of Sr and of Cs makes specific capture hard as well. The Na concentration is 6 orders of magnitude higher than the Sr concentration, and something like 5 orders of magnitude higher than the Cs concentration.
  • #8,414
MadderDoc said:
Attached photo mosaic of frames from video of the unit 3 spent fuel pool. Particularly eye-catching, imo, is the apparent gross damage to the steel liner of the pool. I find it difficult to imagine how a hydrogen explosion at the service floor could have left the pool liner in this condition.
If that's the pool liner then I find it even more difficult to imagine what is now keeping the pool full of water and how the liner transformed itself from stainless steel to painted mild steel.
  • #8,415
I dunno, but I think this is the/a pool liner: http://www.tepco.co.jp/en/news/110311/images/110415_1f_4_1.jpg
SFP#3 looks a bit short at its south edge - maybe the FHM is hiding there under the rubble. Could not be proven or excluded.
  • #8,416
Unit 5 was >11h without cooling ?
At 9:14 pm on May 28, we confirmed temporary RHRS pumps were out of service, we started replacement of these pumps with spares at 8:12 am on may 29th
  • #8,417
Longer than that.
The work began at 8.00am on Sunday (2300 GMT Sarurday) to replace the pump and it was completed in four and a half hours.
From
http://www.hindustantimes.com/New-cooling-trouble-at-Japan-nuclear-plant/Article1-703288.aspx
  • #8,418
At some time on May 28th somebody or something has removed several treetops south of the plant: Tepco's webcam facing the south wall of unit 4 now has a considerably better view to it:
  • #8,419
You certainly got a point there, it does not look like stainless steel. Could we be looking at parts of the top fitting to the liner of the pool, at skimmer level? I believe we see top parts of the unit3 pool wall at skimmer level in this photo taken before the disaster:
  • #8,420
Rive said:
<..>I think this is the/a pool liner: http://www.tepco.co.jp/en/news/110311/images/110415_1f_4_1.jpg
I am aware that this photo has been attributed in some fashion by Tepco as having something to do with a spent fuel pool, and specifically the spent fuel pool of unit 3. However it does not look to me like anything coming from unit 3, even less from its spent fuel pool or indeed from any spent fuel pool. It looks more like a pit, or a manhole.
Thank you, I see what you mean now. Indeed there would seem to be room in the rubble on the south service deck to hide the fhm or parts of it. The fhm carrying bridge otoh, is a rather much larger and stronger structure, it ought to be somewhere more or less in one piece, and I doubt that it could be hidden there too.
(But certainly the fhm and its bridge could have been dislodged from each other
in the course of the explosion, say, with the fhm ending up south while the bridge flipped over and crashed into the north end of the building.)
  • #8,421
interesting, tepco change water leve injected to reactor 2, now it is 12m3/h, why ? Unit 2 is not hot...
also all temperatures in unit 3 are going up
  • #8,422
I don't know but I would love to know what's in the shiny box next to those guys and why its oh so shiny.
  • #8,423
http://www.tepco.co.jp/en/news/110311/index-e.html New photos from reactors
  • #8,424
I guess, they want to tell the press: "Look, the reactor building #4 is in really good shape!"
  • #8,425
That reminds me. How many floors does reactor 3 building have? And how many were destroyed? Is building four the same design?
  • #8,426
More detail in this article.
http://search.japantimes.co.jp/cgi-bin/nn20110529x1.html
  • #8,427
The pictures are part of "Reports about the study regarding current seismic safety and reinforcement of reactor buildings at Fukushima Daiichi Nuclear Power Station" : http://www.tepco.co.jp/en/press/corp-com/release/11052801-e.html not yet translated into English. The erratum published today http://www.tepco.co.jp/nu/fukushima-np/images/handouts_110529_03-j.pdf (Japanese) concerns picture captions among other things.
  • #8,428
They are switching from fire extinguishing line to reactor feedwater line. They already did this at reactor 3, but the detail was somewhat lost because we were mostly paying attention only to the struggle against rising temperatures at reactor 3 at the time. Anyway they do this switch quite slowly over a number of days, first starting to inject more and more water through reactor feed water line, then gradually reducing water rate from fire extinguisher line. At reactor 3 there is no longer any water coming via fire extinguishing line, switchover is complete, but reactor 2 is much earlier in the switch process so for a while we will see both lines being used, and higher total flow rate.
I don't actually know why they want to switch away from fire line, I asked about this recently on this thread but nobody responded.
  • #8,429
From the article: http://search.japantimes.co.jp/cgi-bin/nn20110529x1.html
"Unlike reactors 1 through 4, No. 5 is less at risk of meltdown because it was not damaged by hydrogen blasts as the others were and because workers managed to restore external power to run its cooling system."
Is it just me or does the above not make sense?"The temperature of the core and the fuel pool had reached 93.6 degrees and 46 degrees, respectively, by noon Sunday compared with 68 degrees and 41 degrees at 9 p.m. Saturday.
The backup pump kicked in at 12:31 p.m. Sunday, and the temperature of the core had been brought down to 83 degrees by 1 p.m., a Tepco spokeswoman said by phone later Sunday.
The temperature must stay below 100 degrees to maintain cold shutdown status.
'We judged that it's better to wait for the morning, rather than to start working while it's dark. We didn't think it would pose any immediate danger,' Matsumoto said.
'Even if the temperature (of the core) reaches 100 degrees, the alternative water-injection system is available,' he said."
Working while it's dark? They had power at unit 5, see first quoted paragraph. And is it really okay to let the temperature rise that high without using the alternative water-injection system?
  • #8,430
Does the above make sense?
No
They should change pump without waitning, also there was information that pump could be damaged by salt water, so they are injecting salt water to 5 ??
49K
  • · Replies 41 ·
  • · Replies 2K ·
60
459K
20K
  • · Replies 763 ·
279K
  • · Replies 38 ·
16K
12K
