Master Java Homework: Learn to Create Random Math Addition Questions with Ease!
  • Thread starter Thread starter xLaser
    Homework Java
To create a program that displays a random math addition question in Java, users need to utilize the Random class to generate two random integers. The nextInt(max) method from the Random class can be used to select a random number within a specified range. The program should then prompt the user for the sum of these two numbers and check if their answer is correct. Understanding how to implement this functionality is essential for completing the assignment. Mastering these concepts will enhance programming skills in Java.
xLaser
Question: Write a program which displays a random math addition question, asks the user for the answer and tells them whether they are correct or not.
ok, what is the command in java that creates an random math additon question?@#$% I have never heard of something like this before!
There isn't one! Writing that functionality is part of your assignment.
(Java does have a feature for generating random numbers, though! Check out the `Random' class)
I think what the program specifications are asking you is to write a program that picks two numbers and asks the user to input their sum.
Like Hurkyl said, there is a Random class and an object of that class has a nextInt(max) method that will pick a random integer from 0 to max (I forget if it's inclusive or not).
got it, thanks dudes.
