Where can I find a compatible JTag connector for my PCB?
  • Thread starter Thread starter DailyDose
    Pcb
A user is seeking a compatible JTag connector for a PCB with 16 pins, requiring a through-hole design with 5-1 mm spacing. They have struggled to find suitable options online and are asking for recommendations on websites that specialize in these connectors. Another user suggests a specific part number from Digi-Key, 952-1383-ND, and inquires about the intended JTAG programmer for compatibility. The discussion highlights the need for precise specifications in sourcing electronic components. Finding the right connector is essential for successful PCB integration.
DailyDose
Hello,
I am looking for a JTag connector for my PCB. I have 16 pins and the JTag connector needs be throughole that I can solder and about 5 - 1 mm spacing. I have searched throughout the internet and I am not finding anything. Does anyone know of websites that special make these things by chance?
DailyDose said:
Hello,
Welcome to the PF.
What connector do you want to mate with? What is the JTAG programmer that you want to use with your PCB?
http://www.google.com/search?tbm=is...&q=jtag+connector&gbv=2&aq=f&aqi=g10&aql=&oq=
The digi key part number is 952-1383-ND. That's the connector. Nevermind the 16 pins like mentioned earlier. The adapter is JTAGICE-mkII. But I am open to other options.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
