Junction Capacitance in a GaAs Photodiode
The discussion centers on estimating the junction capacitance of a GaAs photodiode across varying bias voltages, with the user struggling to achieve expected results. They reference equations from a semiconductor physics textbook but find their calculations yield values significantly off from expectations, suspecting incorrect variable values. Other participants inquire about the specific photodiode model and expected capacitance, with one mentioning a previous calculation of 250pF at 0V. The user acknowledges the need to correct their variable values but has not yet provided detailed calculations for review. Clarification on the equations and accurate variable values is sought to resolve the discrepancies in capacitance calculations.
GraemeC
I am trying to get an estimation the junction capacitance of my GaAs Photodiode with respect to varying bias voltages.
My Semiconductor Physics online textbook gives the following equations
with
ε0 = permittivity of free space
εGgAs = GaAs dielectric constant
μ = Mobility of electrons
ρ = resitivity
Vbi = built-in voltage
VA = Bias voltage (in my case 0 - 5V)
A = photodiode area (in my case 0.3μm2)
Whenever, I work through the calculations I get answers that are many orders of magnitude off what I expect
I think the main issue is just getting the correct values(in the correct units) for each of the variables as I have been pulling them in from different sources.
Any help would appreciated.
Welcome to PF.
What is the make and model of the photodiode ?
What capacitance do you expect ?
It's custom part.
My colleague did a calculation a while back and came up 250pF at 0V
I'm getting femtoFarads which is definitely not right!
You haven't shown us your work. You seem to have diagnosed your problem is, but haven't taken the step of fixing it. What exactly are you asking for?
Confirmation that the equations I've given are correct and then values for
ρ = resitivity
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
