Just an easy problem of physics
  • Thread starter Thread starter NeoPhoenix
    Physics
To pull a block weighing 5N with a rope that can withstand 20N, the minimum force exerted must be greater than 5N but less than or equal to 20N to avoid breaking the rope. A free-body diagram illustrates the forces acting on the block, including tension and gravitational force. Applying Newton's second law, the net force must equal the mass times acceleration. Therefore, the force required is calculated by ensuring it does not exceed the rope's limit while overcoming the block's weight. The solution confirms that a force of 5N is necessary to start moving the block without breaking the rope.
NeoPhoenix
If we want to pull a block with a weight of 5N attached to a rope that is just able to resist 20N. What is the minimum force that we need to exert in order to not break the rope? xD
Draw a free-body diagram on the block, write out Newton's second law, and solve!
