Just started my physics class. Already
  • Thread starter Thread starter Damie904
    Class Physics
The discussion revolves around solving a physics problem involving a tiger leaping horizontally from a height. The key points include identifying the initial conditions: a height of 5.5 meters and a horizontal speed of 3.1 m/s. The main challenge is determining how to calculate the horizontal distance traveled using the time of flight derived from vertical motion. The equations provided highlight the need to separate vertical and horizontal components to find the total distance. Understanding the relationship between time and the two-dimensional motion is crucial for solving the problem effectively.
Damie904
Just started my physics class. Already need help!
A tiger leaps horizontally from a 5.5 m high rock with a speed of 3.1 m/s.
So I know
Height=5.5 meters
Initial Velocity=3.1 m/s
How far from the base of the rock will she land?
I honestly have no idea how to attempt this problem. The only equation I can think of is requires me to know what theta is to find the distance and I don't know how to find it. I don't want an answer I just want to know how I'd go about finding it.
Well you know that d = (Vi)t + 1/2(at^2) right? Remember that time is the variable that is the same in both the horizontal and vertical decomposition of the 2d movement and in free fall all other variables can be treated independently in the vertical and horizontal decomposition. If you can find the time for the vertical then you can use this same time to find the total distance traveled along the horizontal with the same equation but, again, for the horizontal component.
The position-time equations for a horizontal hit are:
<br /> \begin{array}{l}<br /> x = v_{0} \, t \\<br /> <br /> y = h - \frac{g \, t^{2}}{2}<br /> \end{array}<br />
To this, you need to translate the information given in the problem in terms of math. What condition has to be fulfilled (in terms of the coordinates) for the tigar to hit the ground? What coordinate measures the distance from the base? What variable has to be eliminated from the two equations?
