Just tell me if this is even possible
  • Thread starter Thread starter Mustapha13
    even
It is possible to determine the time it takes for a tennis ball to hit the ground and its final speed if the initial speed and the height of the building are known. The kinematic equations for constant acceleration can be used, specifically incorporating the acceleration due to gravity, which is -9.8 m/s². Once the ball is thrown, it is only influenced by gravity, allowing for calculations based on its initial conditions. The discussion emphasizes the importance of using these equations to solve for the desired variables. Understanding these principles is crucial for solving similar physics problems.
Mustapha13
Let's say that my friend throws a tennis ball down a building.
is it possible for me to find the time at which it hits the floor and at what speed it it is when it hits the floor. If he only tells me the initial speed and length of the building?
2. The attempt at a solution
(according to my thoughts, it seems impossible unless he tells me the time interval or the final speed, idk am i suppose to use the -9.8 acceleration for something?)
yes, it is possible. You need the kinematic motion equations for constant acceleration. In this problem, once the ball leaves the thrower's hand, at an initial speed, the ball is now subject only to the force of gravity, thus, it's acceleration must be ____?____.
9.8 m/s^2
Thanks a lot for the reply .
