How Can You Calculate Jupiter's Mass Using Callisto's Orbital Data?
In summary, the planet Jupiter has at least 14 satellites, one of which is Callisto with a period of 16.75 days and a mean orbital radius of 1.883 x 109 m. Using the formula T2 = (4∏2/ GM)r3, the mass of Jupiter can be calculated to be 1.89 x 1027 kg. It is important to keep the units consistent in calculations and not simply plug in values without considering the units.
BrainMan
279
The planet Jupiter has at least 14 satellites. One of them, Callisto, has a period of 16.75 days and a mean orbital radius of 1.883 x 109 m. From this information, calculate the mass of Jupiter.
T2 = (4∏2/ GM)r3
∏ = pi
I attempted to plug the values into the above formula to find the mass
(16.75)2 = (4∏2/6.673 x 10-11M)(1.883 x 109)3
280.5625 = (1.883 x 109)34∏2/ 6.673 x 10-11M
280.5625 M = (1.883 x 109)34∏2/ 6.673 x 10-11
280.5625 M = 3.95 x 1017
M = 1.4 x 1015
The correct answer is 1.89 x 1027 kg
What is the SI unit for time?
Also, when you divided by 6.673 x 10-11, I think you must have plugged in 6.673 x 10+11 in your calculator.
Likes 1 person
OK I figured it out. Thanks!
This was the source of your difficulties. I realize you have already solved this problem, but don't just "plug the values into the above formula".
Keep the units in your expressions. G is not 6.673×10-11. It is 6.673×10-11 m3⋅kg-1⋅s-2. Change the units and you'll get a different value for G. If you had carried the units in the expression you would have realized you have a units mismatch between the period in days and the seconds used in G. Other students experience similar difficulties when distances are expressed in kilometers rather than meters. These problems go away (or at least you are alerted to them) if you keep those units in your expressions.
Your attempt at solving the problem using Kepler's Third Law is on the right track, but there are a few errors in your calculations. First, you have not converted the orbital radius from meters to kilometers, which is the unit typically used in this formula. Second, you have not squared the orbital radius before plugging it into the formula. Lastly, your calculation for pi (∏) is incorrect. It should be approximately 3.14, not 1.4.
The correct solution using Kepler's Third Law is:
T2 = (4∏2/ GM)r3
(16.75)2 = (4 x 3.14^2/ GM)(1.883 x 109)^3
280.5625 = (39.478/ GM)(6.694 x 1027)
280.5625 x (6.694 x 1027) = 39.478/GM
1.879 x 1030 = 39.478/GM
GM = 39.478/1.879 x 1030
GM = 2.103 x 10-31 m3/s2
Therefore, the mass of Jupiter (M) can be calculated as:
M = GM/r3
M = (2.103 x 10-31)/(1.883 x 109)^3
M = 1.89 x 1027 kg
This is the correct answer for the mass of Jupiter, which is consistent with the known values. Keep in mind that this calculation assumes that Callisto's orbit is perfectly circular, which may not be the case in reality.
What is Kepler's Third Law problem?
Kepler's Third Law problem, also known as the "Harmonic Law", is a mathematical relationship that describes the orbital period of a planet around the sun based on its distance from the sun.
Who was Johannes Kepler?
Johannes Kepler was a German astronomer and mathematician who lived in the 16th and 17th centuries. He is best known for his work on Kepler's Laws of Planetary Motion, which laid the foundation for modern celestial mechanics.
What is the mathematical formula for Kepler's Third Law?
The mathematical formula for Kepler's Third Law is T^2 = k * r^3, where T is the orbital period of a planet, r is the distance of the planet from the sun, and k is a constant value.
How does Kepler's Third Law apply to our solar system?
Kepler's Third Law applies to our solar system by predicting the orbital period of each planet based on its distance from the sun. This relationship is also used to calculate the orbital period of other celestial bodies, such as moons and comets.
What are some real-life applications of Kepler's Third Law?
Kepler's Third Law has many practical applications, including predicting the positions of planets and other celestial bodies in our solar system, determining the mass of exoplanets, and calculating the orbits of satellites and spacecraft.
  • Classical Physics
  • Astronomy and Astrophysics
