Ket-vector and bra-vector in dual space (for qutrits)
  • Thread starter Thread starter limarodessa
    Dual Space
limarodessa
There are three qutrits which are connected by quantum entanglement:
|\Psi\rangle=\frac{1}{\sqrt{3}}\left( {|021\rangle+|102 \rangle+ |102 \rangle} \right)
How can I to describe \langle\Psi| ?
\langle\Psi|=\frac{1}{\sqrt{3}}\left( {\langle ... |+\langle ... | + \langle ... | } \right)
What must I write instead points in angle brackets - {\langle ... |} ?
I think in case:
|\Psi\rangle=\frac{1}{\sqrt{3}}\left( {|012\rangle+|120 \rangle+ |201 \rangle} \right)
it will :
\langle\Psi|=\frac{1}{\sqrt{3}}\left( {\langle 210 |+\langle 021 | + \langle 102 | } \right)
but i do not know what I must write in case
- I do not know what it will in
limarodessa said:
I think in case:
it will :
If try to use this to compute ##\langle \Psi | \Psi \rangle##, you'll find zero, which is not possible. Therefore the expression for ##\langle \Psi|## is wrong.
In order to understand why, you should make sure that you understand exactly what we mean by the expression ##|abc\rangle##. This is a state in a Hilbert space describes the composite states of 3 identical particles, each of which can be in 3 orthonormal single-particle states ##| a \rangle ##, ##a-0,1,2##. In fact,
$$ | a b c \rangle = |a\rangle \otimes | b\rangle \otimes | c\rangle,$$
where the ##\otimes ## symbol denotes a tensor product. The first term in the tensor product is the state of the first particle, the second term for the second particle, etc.
Since the single particle states can be taken to satisfy an orthonormality condition ##\langle a' | a \rangle = \delta_{a'a}##, we want the conjugate states to satisfy the analogous condition
$$ \langle a'b'c' | a bc\rangle = \delta_{a'a}\delta_{b'b}\delta_{c'c}.$$
You should try to work out the form of ##\langle a'b'c' |## such that this is true. If necessary, consider the general form that the bra could take:
$$\langle a'b'c' | = \sum_{abc} M_{a'b'c'abc} \langle a | \otimes \langle b|\otimes \langle c|.$$
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
