Kicking a Field Goal: Initial Speed Needed for Clear Crossbar
  • Thread starter NotVeryBright
  • Tags
    Field
In summary, the problem requires finding the initial speed of a ball kicked at 53 degrees above horizontal to just clear a 3.05m high goal post. The equations Voy=Vosin(theta) and Vox=Vocos(theta) will be used, along with the equation for motion x(t) in the horizontal direction and the equation for motion y(t) in the vertical direction, to solve for the initial velocity.
NotVeryBright
If the ball is kicked at 53 degrees above horizontal what must the initial speed be if it is just to clear the crossbar. I know the ball is distance in the x direction is 10.98 m and the height of the goal post is 3.05 m.
I think I should be using the equations Voy=Vosin(theta) and Vox=Vocos(theta)
No idea how to solve without having any veclocities to plug into the above equations.
Welcome to the PF. I moved your thread from Advanced Physics to Introductory Physics.
You have listed two of the equations that you will need to solve the problem. Now list the equation for motion x(t) in the horizontal direction, in terms of Vx(t) and Vox and t. And list the equation for motion in the vertical direction y(t), in terms of Vy(t) and Voy and t and the acceleration of gravity g.
With those equations of motion, and the ending (x,y) point you are given, do you see how you may not need to know the initial velocity Vo?
As a scientist, it is important to approach problems with a clear and systematic methodology. In this case, we are looking for the initial speed (V0) needed for a field goal to clear the crossbar, given the angle (53 degrees), distance in the x direction (10.98 m), and height of the goal post (3.05 m).
First, let's break down the problem into smaller components. We know that the motion of the ball can be described as a projectile, with an initial velocity (V0) and an angle (theta) above horizontal. We also know that the ball will follow a parabolic path, with a maximum height at its peak.
Using the equations provided, we can set up a system of equations to solve for V0. The equation for the vertical component of velocity (Voy) is Voy=V0sin(theta), and the equation for the horizontal component of velocity (Vox) is Vox=V0cos(theta).
Since we are looking for the initial speed needed for the ball to just clear the crossbar, we can set up a relationship between the height of the goal post and the maximum height of the ball. This can be done by using the equation for the maximum height of a projectile, which is hmax=Voy^2/2g, where g is the acceleration due to gravity.
We also know that the distance in the x direction (10.98 m) is equal to the horizontal component of velocity (Vox) multiplied by the time of flight (t). This can be represented as 10.98=V0cos(theta)*t.
Now, we have three equations with three unknowns (V0, theta, and t). We can use algebraic manipulation and substitution to solve for V0.
Once we have found the initial speed (V0), we can use it to calculate the time of flight (t) and the angle (theta) needed for the field goal to clear the crossbar. It is important to note that the initial speed needed may vary depending on the specific conditions, such as air resistance and the type of ball being used.
In conclusion, as a scientist, it is important to approach problems systematically and use mathematical equations to solve for unknown variables. In this case, we can use the equations for projectile motion and set up a relationship between the height of the goal post and the maximum height of the ball to solve for
1. What is the optimal initial speed needed for a field goal to clear the crossbar?
The optimal initial speed needed for a field goal to clear the crossbar depends on several factors, including the distance from the goal post, the angle of the kick, and the wind conditions. Generally, a speed of 55-60 mph is considered ideal for a successful field goal.
2. How does the distance from the goal post affect the initial speed needed for a field goal?
The farther away from the goal post, the higher the initial speed needed for a field goal to clear the crossbar. This is because the ball will have to travel a greater distance and therefore lose more speed due to air resistance. A longer kick also requires a higher trajectory, which requires more initial speed.
3. Does the angle of the kick affect the initial speed needed for a field goal?
Yes, the angle of the kick can greatly impact the initial speed needed for a field goal. A kick with a higher angle (closer to 90 degrees) requires less initial speed, while a kick with a lower angle (closer to the ground) requires more initial speed to clear the crossbar.
4. How do wind conditions affect the initial speed needed for a field goal?
Wind conditions can have a significant impact on the initial speed needed for a field goal. A strong tailwind can help the ball travel farther and require less initial speed, while a headwind can slow the ball down and require more initial speed to clear the crossbar. Crosswinds can also affect the trajectory of the ball, making it more difficult to accurately gauge the initial speed needed.
5. Are there any other factors besides initial speed that can affect a field goal's success?
Yes, there are several other factors that can affect a field goal's success, including the skill and technique of the kicker, the condition of the playing surface, and the pressure of the situation. These factors should also be considered when determining the initial speed needed for a successful field goal.
12K
