Kinecti energy of the electron
  • Thread starter Thread starter Xamfy19
    Electron Energy
A 15-eV photon interacting with a hydrogen atom can free an electron, but not all the energy is converted into kinetic energy. The energy required to free the electron from the ground state is approximately -13.6 eV, leaving 1.4 eV for kinetic energy. This results in a kinetic energy of 2.24 x 10^-19 J. The velocity of the ejected electron is calculated to be 7.02 x 10^5 m/s. The discussion clarifies that only the excess energy contributes to the electron's kinetic energy.
Xamfy19
Hello, please help with the following question:
the hydrogen atom is in ground state when a 15-eV photon interact with it and all the photon's energy is transferred to the electron,, freeing it from the atom.
a) what is the energy of the ejected electron
b) the de Brogle wavelength of the electron.
I thought the energy is 15ev x 1.6 E-19 = 2.4 E-18 J, however, I am not sure the total energy is turned into kinetic energy
I guess if the total energy is kinetic energy, then I can use 1/2 * mv^2 to get v, then
wavelength = h/mv (where h is Planck's constant)
Am I right?
Thanks.
Yep, sounds ok to me!
Am I right?
Thanks.
The total energy of the photon is not converted into kinetic energy. If the electron is in the ground state of hydrogen (something like -13.6 ev as I recall, but check on that) that much energy is needed to free it from the nucleus. Only the excess energy is going to result in kinetic energy.
The amount of energy required to free electron is -13.6 ev, as you mentioned. This left 1.4 eV for kinetic energy. A total of 2.24 x E-19 J (1.4 x 1.6 E-19) is kinetic energy.
v = 7.02 E5 m/v, That's what I got.
Thanks alot
