Kinematics: Angled Projectile Launch
The discussion revolves around determining the initial velocity of a projectile launched from a cannon at a 20° angle. The problem involves kinematics and the decomposition of motion into horizontal and vertical components.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss splitting the motion into x and y components and using kinematic equations. There are questions about the assumptions made regarding initial vertical velocity and algebraic manipulations. Some participants express confusion about the variables involved and seek verification of their calculations.
The discussion is active, with participants providing feedback on each other's approaches and calculations. There is an acknowledgment of mistakes and attempts to clarify the relationships between the components of velocity. Some guidance has been offered regarding the algebra involved and the use of trigonometric relationships.
Participants mention feeling uncertain about their understanding and calculations, indicating a learning environment where assumptions and methods are being critically examined. There is a sense of camaraderie among those who identify as beginners in physics.
SlooM
Determine the initial velocity of the projectile as it comes out of a cannon at a 20° angle.
d = (Vi)(t) + 1/2(a)(t)^2
I've split the question into both x and y components and solved for both using the equation above. Although I'm honestly unsure if I'm doing this correctly, would like some verification on my answer and point out any mistakes. Much appreciated! (Image below)
http://imgur.com/pPWO2jG
Hi SlooM,
Are you sure v0y is 0 in the first equation that you've used to find t?
Ah, I think that may have been my mistake which is kind of why I look at it and it doesn't make sense. I just put 0 for v0y and assumed it canceled that half of the equation. What would I put though, I feel like I don't have enough variables and am super confused.
In addition to what Sunil has stated, there was also an algebra mistake at the end preventing you from getting the correct answer.
[tex]\cos\theta = \frac{v_x}{v_i}[/tex]
to
[tex](cos\theta)v_x = v_i[/tex]
instead of
[tex]v_i =\frac{v_x}{cos\theta}[/tex]
An easier way to do this problem it to remember that your x-component of velocity already has a cosine term in it. So once you solve for time you can simply say
[tex]x(t) = V_otcos\theta[/tex]
Oh! I can't believe I didn't see that. So I redid the algebra at the end and got 44.5 m/s but are my calculations in the previous x and y calculations correct? I keep second guessing myself :/
I'm a rookie at physics but trying to improve. I appreciate all of your help and it means a lot.
Hey we are all rookies :smile:
We get two equations right?
[itex]-1.5= v_{0y}t + \frac{g}{2}t^2[/itex]
[itex]23=v_{0x}t[/itex]
All we have to do is eliminate t. Moreover, v0x and v0y are related. So, you should be able to find v0x explicitly (and hence v0y).
Could you check you answer again? I seem to be getting something different.
28K
10K
