Calculating Acceleration and Time for Blood Flow in the Left Ventricle
  • Thread starter Thread starter shawonna23
    Kinematics
The problem involves calculating the acceleration and time for blood flow in the left ventricle, with the final velocity of +22 cm/s and a displacement of +1.7 cm. The calculated acceleration is 142.353 cm/s², derived using the equation v final² = v initial² + 2a(displacement). The time taken to reach this velocity is 0.155 seconds, calculated using the equation v final = v initial + a*t. The solution was confirmed as correct by another participant in the discussion. The calculations demonstrate a clear understanding of the physics involved in blood flow dynamics.
shawonna23
Can someone tell me if I solved this problem correctly?
The left ventricle of the heart accelerates blood from rest to a velocity of +22 cm/s.
(a) If the displacement of the blood during the acceleration is +1.7 cm, determine its acceleration (in cm/s2).
142.353 cm/s2
(b) How much time does it take for the blood to reach its final velocity?
0.155 s
For a, I used the equation v final^2= v initial^2 + 2a(displacement)
vfinal=22cm/s
vinitial=0
displacement=1.7cm
For b, I used the equation v final= v initial + a*t
Looks good.
Thank you!
