Kinematics Problem: Time to Reach Maximum Height with Initial Velocity 30m/s
A ball is thrown upward with an initial velocity of 30 m/s, and it takes 3 seconds to reach its maximum height, where its velocity is 0 m/s. The height reached can be calculated using the formula d = 30*3 + 1/2*(-10)(3^2), resulting in 45 meters. To find the height at which the ball's speed equals half its initial speed (15 m/s), the time taken is 1.5 seconds, leading to a height calculation of d = (30)(1.5) + 1/2*(-10)(1.5^2), which gives 33.75 meters. The discussion emphasizes the importance of correctly applying kinematic equations and understanding average speed concepts.
tommy2st
A ball is thrown vertically upward from the ground with an initial velocity of 30 m/s. Assume the acceleration due to gravity is g = 10 m s-2.
How long will it take for the ball to rise to the highest point on its trajectory? (AF:no decimals)
i got v1 = 30m/s
a= 10m/s2
x1=0
but i can't think of where to start given this information can someone point me in the right direction
What will be the velocity of the ball when it reaches the highest point of its trajectory?
0 is the final velocity. is the answer 3s? i think i may have got it
30=10t
t=3
anyone am i right?
also the height it reaches using 3?
would i use d=30*3 + 1/2(10)(3^2)
anyone?
30=10t
t=3
anyone am i right?
Right!
Almost. Careful with signs.
would it be d= 30*3 + 1/2(-10)(3^2)?
giving me 45?
giving me 45?
Yep!
You can also solve it using the concept of average speed. What's the average speed of the ball as it rises?
average speed 15 m/s?
also i need help with this part... On the way up, at what height is the speed of the ball equal to half its speed of projection?
i get that it wants me to find at what distance v = 15 but I am having trouble munipulating the equations to solve this
Right. So you can find the distance using average speed X time.
Solve it exactly as you solved the first part. First figure out the time.
okay thank you ill try and edit this
t=1.5
d=(15)(1.5)+(1/2)(-10)(1.5^2)= 11.25?
or (30)(1.5)+(1/2)(-10)(1.5^2)= 33.75?
i think its the second one
t=1.5
Right. The initial velocity is 30 m/s, not 15. (That's the final velocity.)
Verify your answer using the average velocity method.
thank you so much for your help doc!
