pankazmaurya
- 26
- 0
pankazmaurya said:watz gung wrong here
jarednjames said:Your spelling. Please not the rules on English and text speak.
This looks like homework. Could you provide your opinion on the matter?
zhermes said:What do you think?
pankazmaurya said:if this looks like homework to you then you should better know its answer
jarednjames said:Yes, it looks like homework and as such the PF rules require your attempt first.
Once we've got that I'll gladly offer my answer to the problem.
pankazmaurya said:though i m not able to get the problem clearly but i have understood that there is a blunder in considering the train frames of reference to apply the work energy thereom
jarednjames said:And what do you think the blunder is?
pankazmaurya said:that is wat I am not geting.now ur chance...
jarednjames said:I'd lose the attitude, I'm not going to tell you the answer. The rules of PF are that I cannot do your work for you and I have no intention of doing so. I can only provide you guidance.
So let's get you started.
What is the formula for kinetic energy? What are the two relevant formulas for work done?
pankazmaurya said:its simple u can't tell the answer becuase you don't know. and my dear m not interested in the answer .
jarednjames said:I've just derived the answer on a pad in front of me for you.
I can tell you it's relating to the KE work done and velocity equations.
Drop the attitude or no one here will help you. If you don't care about the answer I recommend this thread be locked right now as any further help will be pointless if you don't care about it.
I again refer you to the rules you agreed to when you signed up relating to you must show some attempt before we can help.
pankazmaurya said:would you elaborate on your bakwas...
what kind of efforts do you want
jarednjames said:Last chance or I'll report the thread and stop offering help. Drop the attitude.
You indicated you're not sure where to begin, so I pointed you in the direction by asking you for some equations:
pankazmaurya said:stop being bossy...
the energy of the fuel will be converted to kinetic energy of the car according to half my square
lalbatros said:This homework has already been discussed once of this forum.
No need to do it twice.
lalbatros said:I could not give you the link, since this would amount to giving you an answer to an homework.
pankazmaurya said:they are right according o me...
jarednjames said:So Peter is right saying it will take 3x litres of fuel to go from 100 to 200 and Paul is right saying that it will take (5/3)x litres of fuel to go from 200 to 300?
Are you telling me it would take less fuel to go from 200 to 300 than it would 100 to 200?
Again, look at the values for the speeds - there's something wrong with one set of speeds.
pankazmaurya said:the train in moving in opposite direction of the car and hence in train frame of refrence corrolay pauls frame of refrence the initial speed of car is 100 and after consuming x amount of fuel it will be 500
jarednjames said:Where did you get 500 from?
The kinetic energy to go from 100 to 200 for the car will be the same, regardless of frame of reference. The train is independent and Paul is making a mistake by adding the trains velocity into the equation.
The car goes from 0 to 100 and then 100 to 200. The fuel to go from 0 to 100 is not the same as the fuel to go from 100 to 200. The fuel to go from 100 to 200 is not the same as the fuel to go from 200 to 300. So with Paul using these values he is incorrect.
pankazmaurya said:the fuel required for 0 to 100 in peters frame is same as the fuel required 100 to 200 in pauls frame
...and if u are trying to sat that paul is making mistake by adding trains velocity then how how can conclude that he is making a mistake...becuase he can never know whether he is moving or the car is moving
m not discusing the exact question...i want to discuss the spirit of itjarednjames said:Yes it is, but in his equations he uses it wrongly and includes the trains velocity. If you include the trains velocity, you are including the kinetic energy of the train.
but how will paul know that he is including trains velocity...
Irrelevant to the question.
pankazmaurya said:m not discusing the exact question...i want to discuss the spirit of it
From Paul's point of view the car accelerates from -100 to 0 for the first section, then from 0 to 100 for the second section.jarednjames said:If Paul ignores the trains speed and uses 200 to 300 for the second section.
rcgldr said:From Paul's point of view the car accelerates from -100 to 0 for the first section, then from 0 to 100 for the second section.
