Calculating Kinetic Energy of Meteor
The kinetic energy of a 1g meteor traveling at 30,000 m/s is calculated using the formula KE = 1/2 MV^2, resulting in 450,000 Joules. There is a common misconception that the mass should be multiplied by 4 when the velocity is squared, but this is incorrect. The mass should simply be used as is in the formula without any additional multiplication. The one-half factor in the equation is separate from the squared velocity term. Understanding the correct application of the kinetic energy formula is crucial for accurate calculations.
vandorin
What is the Kineti energy of a 1g (0.001kg) meteor traveling at 30,000m/s? Express your answer in Joules.
KE=1/2MV^2
1/2(.001kg)(30,000)^2 = 450000J
Now since 30,000 is squared, would i have to multiply .001kg by 4, before i did all of this math?
Nope. You just plug .001kg in for M. Out of curiosity, why would you multiply by 4?
I thought that since v is squared, you had to multiply the mass by 4...or is that only if its 2v^2?
Nope, the one half is a separate term from the squared term:
KE = (1/2) * (m) * (v2)
