What Was the Speed of the Car Based on Skid Marks and Kinetic Friction?
To determine the speed of the car based on skid marks and kinetic friction, the final velocity is zero since the car has stopped, and the displacement is measured at 61.9 meters. The coefficient of kinetic friction is 0.460, which allows for the calculation of the car's acceleration using Newton's second law. The mass of the car is irrelevant in this scenario, as the relationship between force, mass, and acceleration will yield the necessary values. By applying the appropriate equations, the initial velocity can be calculated once the acceleration is determined. Understanding these principles is crucial for solving this type of physics problem effectively.
jumptheair
You have been called to testify as an expert witness in a trial involving an automobile accident. The posted speed limit was 70 km/h . The driver of the car slammed on his brakes, locking the wheels, and left skid marks as the car skidded to a halt. You measure the length of these skid marks to be 61.9 m, and determine that the coefficient of kinetic friction between the wheels and the pavement at the time of the accident was 0.460. What was the speed of the car?
fk = uk X n
I have no clue on how to approach this problem. No velocity is given(speed limit is irrelavent i think) and only the displacement and the kinetic friction coefficient is given. And especially without the mass, i am clueless. Any help would be appreciated. Thanks.
Hint: The car's acceleration is assumed to be constant during the braking.
What equations does this fact allow you to use?
The mass is irrelevant as you will see.
List what you know already:
Final velocity = 0 (the car has stopped)
Displacement = (x - x0) which is 61.9m
List what you don't know:
Car's acceleration, a
What you want to know:
Initial velocity, v
Now, assuming the acceleration is constant, what equation with the above variables can be used to find the initial velocity?
Once you have that equation all you will need is the unknown variable, a, in order to find v.
The other equation you have at your disposal is based on Newton's second law (Fnet,x = ma). Apply it your free body diagram (that hopefully you have already drawn...hint hint), and see what relationship do you come up with. I'll bet you'll see a way to find the acceleration that you are missing and also see why the mass of the car is irrelevant.
Got it. Thanks alot!
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
