What is the relationship between intermolecular distance and pressure?
Amith2006
4)Sir,
Please give a hint to solve the following problem.
# In order to double the separation between the molecules (keeping the temperature fixed), how many times the initial pressure should the final pressure be made?
How do you relate intermolecular distance and pressure?
I am guessing you need to relate intermolecular distance to volume first, then to pressure.
Sensou has the right idea. The average interparticle spacing will clearly be related to the density of the gas. You need to figure out the relationship between the two.
Sir,
When I searched the net, I came across the Lennard Jones plot of Energy verses intermolecular distance. In that it has been deduced that,
Molar volume = (Nr^3)/C
where N is Avogadro Number, r is intermolecular distance and C is a number which is dependent on the lattice coordination number. Will it be appropriate to use this expression? The symbol ^ represents power.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
