Kirchhoff's Rules and potential difference
The discussion revolves around calculating the potential difference between points a and b in a circuit with resistors and batteries. Using Kirchhoff's rules, the current was first calculated as 0.00289 A based on the total resistance. The application of Kirchhoff's second rule revealed that the sum of potential changes around the loop did not initially add up to zero, leading to confusion about the expected voltage. After reevaluation, it was clarified that the voltage drop across each resistor is 0.75 volts, confirming that the total potential difference from point A to point B is indeed 3 volts. The discussion emphasizes the importance of correctly accounting for all voltage sources and drops in series circuits.
AirForceOne
Find the potential difference between points a and b. each resistor has R=130 ohms and each battery is 1.5V
Kirchoff's First Rule: at any junction point, the sum of all currents entering the junction must equal to the sum of all currents leaving the junction
Kirchoff's Second Rule: the sum of the changes in potential around any closed loop of a circuit must be zero
Kirchoff's First Rule: since there are no junctions, I just have "I" for the current, going counterclockwise, and I find "I" to be:
I = V/R = 1.5/(4*130) = 0.00289 A
Kirchoff's Second Rule: since there is one loop, I'll set the sum of all the potential changes around the loop to be zero
I redrew the diagram like so:
and when I try to Kirchoff's second rule:
V_ab + V_bc + V_bc + V_cd + V_de + V_ef + V_fa = 0
- 0.375 - 0.375 + 1.5 -0.375 - 0.375 + 1.5 = 1.5
It doesn't add up to zero?
Surely it should be 3 volts instead of 1.5.
Final answer 3 Volts, too?
Thanks. So you if you have a series circuit, and you have multiple voltage sources, you just add up the voltage sources for the V in V=IR to find the current?
True, but probably better to sum the voltages around the loop as you did. You just forgot one of the 1.5's.
My guess of 3V for Vab is wrong! After working out the current I did V=IR to get .75 V on each resistor. But the polarity on them opposes the 1.5 V battery.
It may be easier to look at it this way...
This is a single series circuit, therefore, you know that the current, I, is the same through each component.
Since the resistors all have the same value (130\Omega[/tex]), then the voltage across each resistor is 130I. (Let&#039;s say V = 130I).<br /> At any given point (say point A), the sum of voltages around the circuit must be 0.<br /> <br /> Considering voltage sources as <i>positive</i> values and voltage drops as <i>negative</i> values, we have (from point A, traveling counter-clockwise around the circuit):<br /> <br /> -V + 1.5 - V - V + 1.5 - V = 0<br /> 3 - 4V = 0<br /> 3 = 4V<br /> V = 3/4 = 0.75<br /> <br /> So, the voltage drop across each resistor is, indeed 0.75 volts.<br /> <br /> Use the same logic to determine the voltage from point A to point B.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
