Kirchoff's Law and Critical Points
JJBladester
1. Homework Statement [/b]
What is/are the critical points of Kirchoff's Law:
L\left(\frac{di}{dt}\right) + Ri = E
I solved the differential equation above and got the following solution (which I verified to be correct):
i = \left(\frac{E}{R}\right) + Ce^{-\left(\frac{R}{L}\right)t}
If I remember correctly, the critical points would be when \left(\frac{di}{dt}\right) = 0.
\left(\frac{di}{dt}\right) = \left(\frac{E}{L}\right) - \left(\frac{R}{L}\right)i so you have a critical point when
\left(\frac{E}{L}\right) = \left(\frac{R}{L}\right)i
Is this correct or am I on the wrong path?
Sorry, what is the definition of a critical point in this context? Do they mean critical damping of this series RL circuit, or something else?
I asked my professor about the definition of a critical point in this context. She wrote back:
The critical point of a first order DEQ is the value of the dependent variable found by setting its derivative to zero.
So, my crack at an answer is:
L(di/dt) + Ri = E
di/dt + (R/L)i = E/L
0 + (R/L)i = E/L
i = E/R <----- since "i" is the dependent variable, by setting di/dt = 0, we have a critical point at E/R, or voltage/resistance.
How does this sound?
Seems like you did the math right, I'm just not able to intuit what it means physically.
Current equals voltage over resistance. This is Ohm's law, if I'm not mistaken. If di/dt = 0 then the change in current with respect to time is zero, which means if you have a circuit running at constant current, that current can be measured as voltage/resistance.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
